03 caravan rough idle and hesitation #2327470
06/27/17 12:07 PM
06/27/17 12:07 PM
Midwest
Chargerfan Offline OP
Midwest
I'm at a dead end. Have a 03 caravan with 3.3 that started to have a rough idle while in gear. It acts like there is a miss. When I accelerate it hesitates then goes. One time it started to backfire a little. It is throwing no codes. It also seems to be worse when there is a load on the motor, ie A/C and blower on. What I have done is changed spark plugs, wires, cleaned throttle body and AIT, new throttle position sensor, checked for fraying wires and vacuum leaks( which were none). My question is there anything to look at that won't throw a code? Thought about battery and alternator, but I would think those would throw a code. I haven't checked the battery because I need to buy a new meter. Any help is appreciated.
2011 Challenger R/T
2017 Ram 1500 BIG HORN Edition
Re: 03 caravan rough idle and hesitation [Re: Chargerfan] #2327484
06/27/17 12:42 PM
06/27/17 12:42 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What are the cylinder pressures?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 03 caravan rough idle and hesitation [Re: amxautox] #2327488
06/27/17 12:46 PM
06/27/17 12:46 PM
Midwest
Midwest
Haven't checked. Wouldn't that throw a code?
2011 Challenger R/T
Re: 03 caravan rough idle and hesitation [Re: Chargerfan] #2327496
06/27/17 01:07 PM
06/27/17 01:07 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Fuel pressure is easy to check too.
Re: 03 caravan rough idle and hesitation [Re: Chargerfan] #2327501
06/27/17 01:26 PM
06/27/17 01:26 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Bad injector throwing too much fuel won't throw a code, just replaced one in an 02 3.3, it was so bad it filled the cylinder with fuel.
Re: 03 caravan rough idle and hesitation [Re: gtsdude] #2327504
06/27/17 01:38 PM
06/27/17 01:38 PM
Midwest
Midwest
When I changed the spark plugs there were none that were wet. Also forgot to add I ran some sea foam in the gas.
2011 Challenger R/T
Re: 03 caravan rough idle and hesitation [Re: Chargerfan] #2327520
06/27/17 02:30 PM
06/27/17 02:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Actually any missfire or even a weak cyl should set a code. Has the battery been unhooked lately as it sounds like the addaptive numerator needs to be reset. Unhooking the battery can cause it to loose count and it wont set a cyl missfire until the PCM relearns the addaptive numerator which is how the PCM learns how to count the crank sensor. It wont be able to set missfire codes until it relearns the addaptive numerator so it can count the crank sensor numbers. It usually will reset during a few decells from about 60 mph. Have it put on a scanner to see if the crank sensor is counting because any type of missfire should set a code. Heck I had a Caravan that only had a weak cyl as it was not a dead miss and most people would not have even felt the slight lope. But it kept turning on the check eng lite so the cust brought it into the shop. Ended up having a bent rod causing one piston to not come up as far in the cyl having lower comp. It still fired and was not a dead miss but the crank sensor could see it and set a missfire code. Ron
Re: 03 caravan rough idle and hesitation [Re: 383man] #2327531
06/27/17 02:54 PM
06/27/17 02:54 PM
Midwest
Midwest
I had unplugged the battery after I changed the stuff hoping the computer would relearn. But it didn't change. I just checked and battery an alternator are working fine. Thanks
2011 Challenger R/T
Re: 03 caravan rough idle and hesitation [Re: Chargerfan] #2327547
06/27/17 03:13 PM
06/27/17 03:13 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Coil pack?
Re: 03 caravan rough idle and hesitation [Re: mopargem] #2327635
06/27/17 06:27 PM
06/27/17 06:27 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted By mopargem
Coil pack?
This,
Usually if it does it mainly under light loads. Its either plug wires or coil pack. Seen in dozens of times.
Re: 03 caravan rough idle and hesitation [Re: gtx6970] #2327711
06/27/17 09:37 PM
06/27/17 09:37 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Yep, make sure all the components in the ignition system are working properly. And did you mention that you cleaned or changed the IAC (Idle Air Control)?
When chasing gremlins like this, I like to go to a pick-a-part yard and find a vehicle like the one you are working on that has new parts and pull everything that is even remotely likely to cause an issue. Usually $25 to $50 will get you a couple hundred dollars worth of parts.
Master, again and still
Re: 03 caravan rough idle and hesitation [Re: DaveRS23] #2327726
06/27/17 09:59 PM
06/27/17 09:59 PM
Midwest
Midwest
Yes I cleaned the IAC. Yeah I was thinking that too.
2011 Challenger R/T
