Well, it has been a few years since I relocated to Austin, Tx and my 71 Challenger was needing a new and efficient radiator for this Texas heat so I ordered a new and efficient one...
Once the old radiator was removed and the new one was set to be installed, I found out the brackets do not fit where the old one's were and tried to adjust as much as I could with no luck.
Do you guys know of an mechanic around here who is familiar with Mopars who could help me put this radiator back with the possibility of having to fabricate some brackets to get the radiator and fan shroud back in place.
Thanks for your help!
Luis
