Stock air cleaner won't fit #2326691
06/26/17 12:30 AM
06/26/17 12:30 AM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
I have an Edelbrock 1413 on my 440 Chally and the stock 2 snorkel air cleaner hits the fuel hose and something else on the passenger side of the carb. I guess I need one of those drop kits?
thnx, John
Re: Stock air cleaner won't fit [Re: Moparmaniacc] #2326696
06/26/17 12:41 AM
06/26/17 12:41 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Should fit. I use the same setup. Are you using the cheesy fuel inlet supplied with the carburetor that uses a hose and clamp? No good. Get a 5/16" inlet fitting and use a reproduction fuel line. The original fuel line of the Carter AVS had a slight downward bend as it mated to the carburetor. That is what you need.
