Brakes, is a Córdoba a B body?
#2326588
06/25/17 08:53 PM
06/25/17 08:53 PM
Posts: 835 Alberta
4mulaS
Alberta
I think I know the answer but... Is a 1979 Córdoba a B body? And can I use the brakes off it on a 69 road runner? What parts are required from drum to disc conversion on the 69 runner? Thank you
66Scar
Re: Brakes, is a Córdoba a B body?
[Re: 4mulaS]
#2326631
06/25/17 10:43 PM
06/25/17 10:43 PM
RapidRobert
Is a 1979 Córdoba a B body? And can I use the brakes off it on a 69 road runner? An F body. I believe you can use the spindles which are slightly taller than A/E slider calipers but people have done it with no issues tho I ain't sure exactly what is required.
[Re: RapidRobert]
#2326634
06/25/17 10:54 PM
06/25/17 10:54 PM
Posts: 16,826 Between Houston & Galveston TX
SattyNoCar
1979 = B-body
1980 = J-body
J-body shared the transverse torsion bar suspension of the F and M bodies
John
[Re: 4mulaS]
#2326732
06/26/17 01:52 AM
06/26/17 01:52 AM
Posts: 31,046 Oregon
AndyF
I think I know the answer but... Is a 1979 Córdoba a B body? And can I use the brakes off it on a 69 road runner? What parts are required from drum to disc conversion on the 69 runner? Thank you The knuckles and rotors and caliper adapters will work but you'll want to use calipers that match how you mount the knuckles. You can mount the calipers either to the front or to the rear of the spindle. How you mount the calipers will determine which caliper you need in order to get the hose routing correct. Do you have a anti-sway bar on the car? If so you'll most likely need to mount the calipers to the rear.
[Re: 4mulaS]
#2327353
06/27/17 02:02 AM
06/27/17 02:02 AM
Posts: 835 Alberta
4mulaS
Alberta
I guess my. Ain't concern was knowing if the geometry of the 79 Córdoba spindles was the same as factory 69 b body disc spindles.
When It comes to a bodies, you can use aspen/volare spindles but they are slightly different and change the geometry and angles of the suspension...
Does anyone know for sure if the spindles are bang on here or??
66Scar
[Re: 4mulaS]
#2327373
06/27/17 02:36 AM
06/27/17 02:36 AM
AndyF
The B3 uses a taller knuckle than the early B or B2 cars but it doesn't seem to matter. In fact, it might make the geometry better depending on which theory you subscribe to. If it really bugs you then buy the matching upper control arms from Firm Feel. They sell upper control arms that are designed to work with the taller late model knuckles. I wrote an entire book on Mopar B body cars that included all of this information. Pick it up at Amazon for $20 or whatever they are asking for it these days. https://www.amazon.com/B-Body-Performance-Upgrades-1962-79-Design/dp/1934709301
[Re: 4mulaS]
#2327542
06/27/17 03:09 PM
06/27/17 03:09 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I run the taller knuckles on my 65 Had the As on and the talls seem to handle better.They swap right on.The brakes will work as the master should also.I run 70 C body manual disc master on the ones I do.Mine have been on at least 15 years and no problems.rocky
Chrysler Firepower
[Re: Stanton]
#2327948
06/28/17 10:22 AM
06/28/17 10:22 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
THIS is the magazine article that you need to find and read:
Disc Brake Upgrade: DiscoTech-Mopar Action Aug 1999 Vol 10, Num 5 It's a shame the on line articles are not anymore available either. It was a good one! Somebody posted the mag article's pics somewehere recently.... Maybe at FBBO ?
[Re: NachoRT74]
#2327990
06/28/17 11:25 AM
06/28/17 11:25 AM
Posts: 19,456 north of coder
moparx
Disc Brake Upgrade: DiscoTech-Mopar Action Aug 1999 Vol 10, Num 5 It's a shame the on line articles are not anymore available either. It was a good one! Somebody posted the mag article's pics somewehere recently.... Maybe at FBBO ? if anyone wants a copy of this, i can put it on a PDF and send to your e-mail. give me a day or so when you request.
[Re: 4mulaS]
#2328028
06/28/17 12:32 PM
06/28/17 12:32 PM
Posts: 2,920 Calgary, Alberta Canada
a12rag
K, so the rant about the F,M,J body spindles is that they will be 1/8" taller than the ones you are removing off the old car . . . . I have done this swap on my 70 Bbody . . . no issues with alignment or handling, etc . . . only issue was mounting the calipers to the rear, so had to use mid 80's calipers that have the bleeder screw on top, and then went with Dr. Diff's stainless steel braided brake lines . . . . I have 10k real world miles on the car now and no issues at all . . .
The 79 Cordoba pieces should bolt on and have no issues, however, you might need to mount the calipers on the rear - depends on your sway bar and whether you have the front or rear brake line location for the front wheels/brakes. The slider calipers for the rear would be mid 80's fifth ave, or so . . . check with Dr. Diff . . . he has it all dialed in !!
