possible to pick a trunk lock? #2326050
06/24/17 11:24 AM
06/24/17 11:24 AM
Tacoma, Washington USA
Adam71Charger Offline OP
my keys are lost and possibly in the trunk my 81 chrysler. Has anyone here successfully picked a trunk lock similar to what I would have? I know some are hard to pick without locksmith tools but if there's an easy way to do it what is it? Feel free to pm me if you dont want to post it on a public forum. I really dont want to pay 100 for a locksmith to come out here and open it.
The trunk release in glove box doesnt work. My first plan of action is to take the glove box apart to get to the back of the switch and bypass or feed it 12v and see what happens. If that doesnt work, I want to try picking it. Locksmith is last resort
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326052
06/24/17 11:27 AM
06/24/17 11:27 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Did you try removing the rear seat. I'm not sure what your trunk latch looks like but on the older cars you can use a long screw driver to turn the latch from inside the trunk.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326056
06/24/17 11:36 AM
06/24/17 11:36 AM
pay you skinniest neighborhood kid a buck to squeeze thru the back seat area with a socket or if you pick it, cut down a hacksaw blade to make a thin strip & use it to hold the door open & exert a slight CW rotation on the cyl as you reach in with a thin pick & push up each of the 5 tumblers till they "catch" then you can rotate the cyl the rest of the way. it will take a fair amt of practice & I would get the skinny kid to take care of it first.
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326057
06/24/17 11:37 AM
06/24/17 11:37 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Taping a thin blade screwdriver to a broom handle works great if you can get the back seat out.
If you have Chrysler trunk keys from other cars you can try them too.
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326093
06/24/17 01:35 PM
06/24/17 01:35 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i use sockets on long extensions to remove the latch bolts when opening from the back seat.
perception is 90% of reality
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326110
06/24/17 02:20 PM
06/24/17 02:20 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Just drill the pins out with a small bit and use a screwdriver.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: possible to pick a trunk lock? [Re: GTSDart340] #2326111
06/24/17 02:29 PM
06/24/17 02:29 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
That's the way i did it when my road runner's trunk latch cylinder broke and would just spin. Of course the trunk was inaccessible from the rear seats due to the sub woofers so that was the only way in. It worked!
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326123
06/24/17 03:12 PM
06/24/17 03:12 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
The key works, it's just locked in the trunk? Pull the seat back out and grab the key
**Photobucket sucks**
Re: possible to pick a trunk lock? [Re: 70Cuda383] #2326127
06/24/17 03:22 PM
06/24/17 03:22 PM
^^^ that's too easy!
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326202
06/24/17 08:14 PM
06/24/17 08:14 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Isnt the glove box the same key?
Take your glove box lock to a locksmith and have him make a key...
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326229
06/24/17 10:16 PM
06/24/17 10:16 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Once had a father in law who was a locksmith. Would go with him on some lock out service calls This was in 60's. GM cars he had a key ring with a very large number of keys that he would try until one would be jackpot. Somewhat forget what he did with Fords,,,,perhaps the owners if locked out were not interested to pay to gain entrance and just walk away from them.
Mopar's he would insert a blank key, twist and shake it about to make slight impressions on it, remove it, file impressions a bit and try again until lock opened.
He called it to impression the key. Always worked, but he preferred locked out GM's.
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326234
06/24/17 10:41 PM
06/24/17 10:41 PM
Got it. Thank you
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326238
06/24/17 10:54 PM
06/24/17 10:54 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
to answer you original question..
yes it is very possible but you need someone who is good at it.
the easiest way to spot a locksmith hack,
is by how fast he breaks out the drill.
Re: possible to pick a trunk lock? [Re: Sxrxrnr] #2326239
06/24/17 10:58 PM
06/24/17 10:58 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
On a road trip from Detroit to Reno for Hot August Nites in my 69 Bee. We stopped in Iowa for the night. Next morning I'm in the shower, the girl friend thinking she's helping out puts my dirty pants in the dirty laundry bag and puts it in the trunk, which was open, the car doors were locked, closes the trunk. I get out of the shower look for my dirty pants to get the keys and wallet, no pants. I ask her were my pants are, she says in the trunk. Call a local lock smith to come out and open the trunk. He used the impression the key trick. Took him about ten minutes.
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326246
06/24/17 11:14 PM
06/24/17 11:14 PM
Got it. Thank you
what method did you use!
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326295
06/25/17 02:44 AM
06/25/17 02:44 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I have about 30 keys for Mopars, one of them with a little wiggling will open a door, trunk or ignition. Lock goes bad, I get a good one and change the pins to fit the key. Don't even need all five pins, two or three will work.
Re: possible to pick a trunk lock? [Re: Adam71Charger] #2326313
06/25/17 06:20 AM
06/25/17 06:20 AM
I used the switch. Idk what was wrong, I remember this switch never working and I've pressed it a bunch. Today I took the glove box off and pulled the wire to the trunk release and put it back on and it worked. It is possible that I never had the ignition key in an on position while trying before. I hope not. This car is driving me crazy.
Re: possible to pick a trunk lock? [Re: Alaskan_TA] #2326344
06/25/17 10:44 AM
06/25/17 10:44 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Barry,just had to respond to this,couldn't help myself grin !! If the trunk lock arm is engaged in the latch,how would you ever get a thin blade screw driver on a broom handle in from the other side ? no
Re: possible to pick a trunk lock? [Re: cudaman1969] #2326345
06/25/17 10:46 AM
06/25/17 10:46 AM
Agreed, no one picks locks anymore (except in the movies). several junk cyls to choose from is handy so you can select the tumblers to match the key notch depth(s). You want the heights "even" with the key inserted. the tabs on the chrome cover are delicate so bend them just enough so the cover will come off. & there is a specific graphite lube to squirt in there available at your parts house but it ain't absolutely neccessary.
Re: possible to pick a trunk lock? [Re: 62maxwgn] #2326424
06/25/17 01:45 PM
06/25/17 01:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The lock arm isn't that tight a fit. There is room to get a thin screwdriver in between the arm and the latch. Give it a try.
