2006 Ram Engine Codes & Problem
#2324133
06/20/17 12:17 PM
06/20/17 12:17 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
I replaced the exhaust on my 2006 Ram including the cats and put a catback system on it. Since then, it constantly is throwing the following codes:
P0137 - O2S Ckt Low Volts 1 2 P0138 - O2S Ckt High Volts 1 2 P0420 - Catalyst Efficiency Below Threshold Bnk 1 P2096 - Post Catalyst Fuel Trim System too Lean Bnk 1
Is this all from a faulty O2 sensor or do I have a bigger problem?
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 2006 Ram Engine Codes & Problem
[Re: Erik]
#2324163
06/20/17 01:00 PM
06/20/17 01:00 PM
Erik
Stroudsburg, PA
Aftermarket cats from Rock Auto. Dealer ordered and installed them so I assume they changed the gasket as well.
[Re: Erik]
#2324176
06/20/17 01:23 PM
06/20/17 01:23 PM
Erik
Stroudsburg, PA
Yes, stock replacements and the Y pipe is a two piece. I'll check all the bolts to ensure all it tight. I don't see/hear any leaks or ticking noise.
[Re: Erik]
#2324200
06/20/17 02:12 PM
06/20/17 02:12 PM
Erik
Stroudsburg, PA
Should I just replace them and see?
