Front End Issues Continue to Haunt Me
#232188
02/22/09 12:13 AM
02/22/09 12:13 AM
Posts: 3,746 Riverside, California
Lil Demon
I am getting so sick of this front end that I cannot stand it. To fix my previous bump steer issues, I spent money and bought new steering arms from LRT, adjustable tie rod ends, factory spindles, and put coil overs on it.
The car aligned great for the first time since I've owned with no issues going forward or backward - woohoo - problem solved and money well spent. Not so fast...........
Today - the car goes straight as an arrow down the track, I cross the stripe and let off and hit the brake - vicious - and I mean vicious front end shake. So bad that I couldn't see - I wanted to pull the parachute handle but was afraid to let go of steering wheel - it was that bad.
I went back to Les Schwab where we aligned it last night. The caster is at +8 (as much as it can get), the camber is at -1.8, and it was neutral on the toe.
Guys with fast(I know that is relative) back half-4 link cars - what are your front settings? Others - any recommendations?
Re: Front End Issues Continue to Haunt Me
[Re: Lil Demon]
#232189
02/22/09 12:23 AM
02/22/09 12:23 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I run about 10* caster, 0 camber and 0 toe in. It sounds like you have something flexing.... were your wheel bearings tight/snug EDIT Also Bill was the front alignment done with the body up 1"... check your toe in at 1" up... it could be going toe out and thats not good ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dthemi]
#232192
02/22/09 12:36 AM
02/22/09 12:36 AM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
I agree..For me 1/16"+- has always worked well in a back half car. You might also just give the front a once over, always a good idea. Never checked that driver side bearing at the track.
[Re: Chuck@Best_Machine]
#232198
02/22/09 12:59 AM
02/22/09 12:59 AM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Had the same problem with the LRT front end on the duster. Also found some cracks in the lower arm. Repaired arm and it is now acceptable.
76 Duster
work in progress
[Re: Edge]
#232199
02/22/09 01:12 AM
02/22/09 01:12 AM
Lil Demon
My front end is very bastardized. Stock front clip, DARE K-Frame (on it when I bought it - I didn't know), Magnum Force tubular uppers (non-adjustable), Stock LCAs, LRT steering arms, Flaming River Pinto R/P, Aldan coil overs. Looking at the vids - the wheels are definitely toeing out when it lifts them in the air. So - if I set the toe at ride height +1" - do I set it at 1/16" in? The negative caster I think may be the best it can get - not sure. I may need adjustable UCAs ![](/ubbthreads/images/graemlins/rant.gif)
[Re: Lil Demon]
#232201
02/22/09 01:22 AM
02/22/09 01:22 AM
MR_P_BODY
Yes set the toe at 1/16 in at 1" up on the body. I assume you just made a error in saying caster instead of camber but you would be better off with adjustable UCA's ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Lil Demon]
#232206
02/22/09 02:24 AM
02/22/09 02:24 AM
Posts: 610 Boise
Moparteacher
Boise
The length of the inner-to-outer tie rod must be equal to the length of the lower control arm (pivot to pivot). They must also rise and drop in a parallel plain. Anything different and you get a change in toe as the suspension goes through jounce and rebound, in other words "bump steer".
The outer tie rod can be shimmed toward or away from the knuckle to obtain the parallel travel, but a rack-n-pinion (inner/outer tie rod) that doesn't match the length of the lower control arms gets a little more complicated.
You can heat and bend the lower ball joint arm up and down or inward or outward to help achieve the equal length and parallel, but only so far.
The Mopar chassis book shows you how to graph changes in toe throughout jounce and rebound and how to correct it. It works for any LSA suspension, but with miss-matched parts there may be only one solution and that's to purchase parts that are engineered to work together.
When it's all said and done camber should be at or near zero regardless. Cross-camber and cross-caster should be less than .5 degree. Preferably zero for a flat track. Excessive positive caster will cause rapid wheel shimmy. You need only enough positive caster to maintain directional stability.
One last thing. Excessive positive scrub radius will put an excessive load on the suspension components and could be a cause for flexing and cracking.
Positive scrub radius occurs when the alignment of the upper and lower ball joints meets the road inside of the point at which the center of the tire meets the road.
Positive scrub radius results from using smaller diameter wheels and tires and/or using a wheel that has little or no offset (common with front runners).
Some positive scrub radius is OK; it's the excessive that causes problems.
Good luck
[Re: Moparteacher]
#232207
02/22/09 02:31 AM
02/22/09 02:31 AM
Lil Demon
Good luck
You know your stuff - now - how close to Rocklin, CA are you?
