Best trans filter? style trans filter for a #2320784
06/13/17 09:33 PM
06/13/17 09:33 PM
jersey
Spaceman Spiff Offline OP
jersey
what's the best style trans filter media?
'65 727, RMVB, 4600lb wagon, 2600 stall, 560hp 630lbft
street car. gets driven 3,000+ miles in the summer northeast months.
does the style of media really matter?
what is the preferred brand?
Thanks.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Best trans filter? style trans filter for a [Re: Spaceman Spiff] #2320892
06/14/17 12:13 AM
06/14/17 12:13 AM
Locomotion Offline
Locomotion  Offline
Not sure if there is a difference between the yellow (Dacron?) ones. But the brass screens do not filter well. They are mainly used for applications where higher flow is needed and fluid is changed more often.
Re: Best trans filter? style trans filter for a [Re: Spaceman Spiff] #2320909
06/14/17 01:11 AM
06/14/17 01:11 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
A magnafine in the return line. The ones in the pan filter out only large over 70 microns.
Re: Best trans filter? style trans filter for a [Re: Spaceman Spiff] #2321012
06/14/17 11:07 AM
06/14/17 11:07 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'd rather have debris in my cooler flow/return system than a place for restriction to start.
Re: Best trans filter? style trans filter for a [Re: Spaceman Spiff] #2321115
06/14/17 02:53 PM
06/14/17 02:53 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
If the magnafine gets clogged it has a bypass, but if it gets clogged that bad the trans is probably toast anyway.
Re: Best trans filter? style trans filter for a [Re: Spaceman Spiff] #2321127
06/14/17 03:15 PM
06/14/17 03:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'65 727, RMVB,
Since you have a RMVB with no rear pump, you can use the '73-later large Dacron filter; that's what I would recommend.
Re: Best trans filter? style trans filter for a [Re: Spaceman Spiff] #2321793
06/15/17 09:00 PM
06/15/17 09:00 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I have the B&M cartridge in the line to my cooler, otherwise it fills up with clutch/band lining and difficult to clean.
Boffin Emeritus
Re: Best trans filter? style trans filter for a [Re: John_Kunkel] #2321865
06/15/17 10:55 PM
06/15/17 10:55 PM
'65 727, RMVB,
iagree scope
