Re: DC sixpack for a 440 [Re: Pentastar440] #2318776
06/10/17 02:05 AM
06/10/17 02:05 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Originally Posted By Pentastar440
Chevrolet carbs had fuel inlets on the driver's side /with mechanical linkage . I've never seen a Mopar setup like that ? I could be wrong .
Not even close to Chevy carbs. These are holley 4782 and 4783 carbs sold by holley, direct connection and hustle stuff specifically for use on 440 mopar.
Re: DC sixpack for a 440 [Re: GomangoCuda] #2318783
06/10/17 02:36 AM
06/10/17 02:36 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Cheby carbs were vacuum, these were mechanical. These were sort of based on 390 or 406 Ferd carbs that were available in the early 60's but were different than those too.
Sheldon
Re: DC sixpack for a 440 [Re: busboy] #2320921
06/14/17 01:31 AM
06/14/17 01:31 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
They run awesome on my SB . Here's an old write up I did on the rebuild with some part numbers.
http://www.forabodiesonly.com/mopar/thre...b-build.275946/
Re: DC sixpack for a 440 [Re: ademon] #2320978
06/14/17 08:37 AM
06/14/17 08:37 AM
Cent, OH
Mopar.70 Offline
Mopar.70  Offline
Cent, OH
I bought this set up a few years back with air cleaner for under 2k. I think my set up is the same, can you guys confirm? I'm about to finish the build on my 71 Challenger and this is going on top of the 440 going in it.
Re: DC sixpack for a 440 [Re: Mopar.70] #2321023
06/14/17 11:27 AM
06/14/17 11:27 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Looks like them, to be sure, check the list numbers on the carbs, should be 4782 center and 4783 outboards beer
Re: DC sixpack for a 440 [Re: busboy] #2321100
06/14/17 02:27 PM
06/14/17 02:27 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Btw keep the jetting close to stock, even my lowly 400hp SB likes 66 center and 80 outboards and that may be to lean!
