Re: 360 4bbl 904 throttle setup
[Re: elmor353]
#2320589
06/13/17 03:22 PM
06/13/17 03:22 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I always understood the service manuals to to say that your kickdown linkage should be pushed all the way back when your throttle was open all the way. FSM never said that. Adjustment is made with the carb at curb idle and the trans lever full forward. From the pics I see that the slot in the top link isn't pulled up against the rear of the throttle stud...it should be, so that the linkage starts to move rearward with the slightest throttle opening.
[Re: cudabitten]
#2320628
06/13/17 04:20 PM
06/13/17 04:20 PM
Challenger 1
Cincinnati, Ohio
Hi all, Been a while since Ive been online. I finished my restore about 3 years ago, and been drivin but knew that my throttle linkage was never really right. I finally compared it to a friend with the same carb (1406) and realized that my secondaries were never opening. Please check the pics. I fabricated the bar that connects the kick down rod to the linkage. Not sure where I got the dimensions, it does work for kicking down, but I'm thinking the slot is not long enough to allow the throttle to fully travel backwards. If I disconnect the rod, then the throttle does open fully and open the secondaries. I'm just not sure about when the kick down should engage/disengage. This was a 318 2bbl/904, I swapped in a 360 4bbl and kept the 904. The kick down rod is original. Sorry but I don't think anyone can tell you how to fix or adjust that. That is a mix of old and new and home made. I would remove it all and stick to one model year and use that linkage. Now you can buy the whole thing repo and have the right parts. When you go from 2 to 4 barrels what you need to do is move the throttle cable up and forward when you go to a 4 barrel and use the right mopar adaptor on the carb. Check these out, Mopar throttle cable clamps. They bolt on a 2 barrel throttle bracket and provides the correct cable mounting location for connection to a 4 barrel mopar throttle linkage. This works if your cable is long enough. They bolt on and move the cable up and forward and you don't have to do what you did above... All you have to do is move the cable clamp, and modify one piece of trans linkage.
[Re: elmor353]
#2320844
06/13/17 11:06 PM
06/13/17 11:06 PM
RapidRobert
I didn't read everything but if you swapped in a shorter spring to pull the slot forward would that take care of it?
[Re: cudabitten]
#2320939
06/14/17 02:28 AM
06/14/17 02:28 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Anybody else notice the angle of the round rod that goes from the intake mounted lower bracket up to the kickdown link bar? If you look at the pic that John posted showing the factory linkage, with the throttle closed the rod is leaned forward, towards the "10 o'clock" angle. As the throttle is pressed, the link bar goes back, with the rod usually ending up at about the 2 o'clock angle. Yours is already starting at the 1 o'clock angle - it has very limited travel rear-wards when the throttle is opened. I always tried to have that rod straight up and down when the throttle was half open. IMO I would start by correcting this before I went further.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Challenger 1]
#2321131
06/14/17 03:22 PM
06/14/17 03:22 PM
John_Kunkel
Rio Linda, CA
I realize the component mix is incorrect but it could be made to work by correcting the leverage ratios. As it is, it appears that the trans lever is full forward and that is preventing the top rod from coming up against the throttle stud.
[Re: moparx]
#2321782
06/15/17 08:24 PM
06/15/17 08:24 PM
John_Kunkel
Rio Linda, CA
Some one-piece rods adjust at the trans lever and some adjust at the top near the U-link.
