Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: Still running hot in traffic with the new aluminum rad [Re: CrAlt] #231980
03/08/09 05:47 PM
03/08/09 05:47 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
And yes, stumpy makes very good and valid points but I can't have that as the fix due to the fact that before I did the intake, carb, radiator, fan switch it was cooling a lot better- even with the current tranny/tc setup. I'd like to tinker with the small things first before swapping parts again.
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231981
03/08/09 06:02 PM
03/08/09 06:02 PM
USA
CrAlt Offline
CrAlt  Offline
USA
This
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Still running hot in traffic with the new aluminum rad [Re: CrAlt] #231982
03/08/09 06:03 PM
03/08/09 06:03 PM
USA
CrAlt Offline
CrAlt  Offline
USA
This
Plus this
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231983
03/08/09 06:04 PM
03/08/09 06:04 PM
Going back to the original stuff probably will help him somewhat.
It runs OK at idle when the air is being pulled through from the backside of the radiator, not being pushed through the condenser.
It heats up at speed.
Aluminum radiators like more airflow than copper/brass.
He has a very restrictive condenser and cooler in front of the radiator.
The aluminum radiator is going to be quite a bit more hurt by the airflow restriction than the copper/ brass one, so it should get better going back.
The best solution is to get rid of the condenser and use the aluminum radiator with good airflow.
Re: Still running hot in traffic with the new aluminum rad [Re: CrAlt] #231984
03/08/09 06:06 PM
03/08/09 06:06 PM
USA
CrAlt Offline
CrAlt  Offline
USA
This
Plus this
== this
Re: Still running hot in traffic with the new aluminum rad [Re: CrAlt] #231985
03/08/09 06:06 PM
03/08/09 06:06 PM
Kirkland, Washington
Pacnorthcuda Offline
This
I wouldn't be buying the MP 5 blade if I was having cooling problems. Use a 7 blade. They even advertise the HP savings with the 5 blade (even over stock clutch units)...the only way to save HP is by moving LESS air.
Re: Still running hot in traffic with the new aluminum [Re: bboogieart] #231986
03/08/09 06:06 PM
03/08/09 06:06 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i run 3:91's with a 3000 stall converter behind my 440 and i do some pretty long distance trips in summer on the highway and there are people running much wilder combos than me. i would try ditching the elec. fan and going with a belt driven type(flex or clutch drive) with a shroud. good luck.
Re: Still running hot in traffic with the new aluminum rad [Re: AHall] #231987
03/08/09 06:16 PM
03/08/09 06:16 PM
ran it down the freeway, did well, exited, sat in traffic 5-10 mins (stop-go) and the needle got over to the "H".
I thought it was acting up when it was idling/stop & go & was OK out on the interstate
Re: Still running hot in traffic with the new aluminum [Re: AHall] #231988
03/08/09 06:26 PM
03/08/09 06:26 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
But damn if this heat issue isnt bugging the hell out of me. Im taching 3000 RPM at 50 mph.
When I got home I popped the hood and grabbed the upper radiator hose going from the thermostat to the top of the radiator and it was hard as a rock. I let it cool, just went out there and it was squishy-- what does that indicate? Is my thermostat stuck?
That's a pretty high RPM for that RPM and 50mph ?
The hose should he hard since the system is under pressure , thats a good ting , and it should get soft once the car cools down as the pressure is much less if not gone .
Re: Still running hot in traffic with the new aluminum rad [Re: RapidRobert] #231989
03/08/09 06:27 PM
03/08/09 06:27 PM
Do you have the coil in the lower hose to prevent collapsing under low pressure from the WP?????
Re: Still running hot in traffic with the new aluminum rad [Re: stumpy] #231990
03/08/09 06:28 PM
03/08/09 06:28 PM
U.S.S.A.
U.S.S.A.
No. A clooged heater core would just mean no heat inside. Get your rpms down and get the slippage cured. Both of those cause excessive heat.
But it looks like he has a seperate trans cooler so the trans will have less of an effect on the cooling system , or is it plumbed into the rad also ?
Re: Still running hot in traffic with the new aluminum rad [Re: stumpy] #231991
03/08/09 06:30 PM
03/08/09 06:30 PM
U.S.S.A.
U.S.S.A.
If the problem was at low speed I could see the a/c condenser and trans cooler being the problem but his trouble is at highway speeds which should rule that out.
That's an air flow issue thru the rad .Here's a test , pull that fan setup out of the car and go for a ride ...
Re: Still running hot in traffic with the new aluminum rad [Re: stumpy] #231992
03/08/09 07:51 PM
03/08/09 07:51 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
What will that show other than that the water moves.. You already know you don't have a problem at idle.
If for some reason the cylinder pressure is getting into the cooling system you might see some bubbles coming up with the car warmed up and radiator cap off. I have seen this type of issue cause a runaway temp condition that would only happen if the car was driven on the highway and then had to sit in traffic, i.e. at the end of an exit on Hwy 75 at 5pm.
Just a thought...
Re: Still running hot in traffic with the new aluminum rad [Re: JohnRR] #231993
03/08/09 07:59 PM
03/08/09 07:59 PM
USA
CrAlt Offline
CrAlt  Offline
USA
I don't think that will help any... He might as well put cardboard over the grille
Re: Still running hot in traffic with the new aluminum [Re: CrAlt] #231994
03/08/09 08:24 PM
03/08/09 08:24 PM
U.S.S.A.
U.S.S.A.
If thats the case why didn't he have an issue with the stock rad and that hi stall convertor ?
Stumpy spelled out the electric fan shroud being restrctive , SHE whose name can not be spoken had the same problem with her RR , alum rad , electric fan and a shroud that blocked flow , it idled fine but once you got it moving it would get way too hot because the shroud was forcing the hot air back into the radiator .
Re: Still running hot in traffic with the new aluminum rad [Re: CrAlt] #231995
03/08/09 08:32 PM
03/08/09 08:32 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I had over heating problems on my aluminum headed small block Dart a few years ago. It had a new replacement radiator with a Flex o Lite Black Magic electric fan on it, standard wp and 180* thermostat. I went to a new aluminum radiator with a new Flex o Lite thin fan, 2700 cfm. It still ran hot so I changed to a Flow Kooler wp and a high flow 160* thermostat, still hot. The fix was a MP (5 blade) viscous fan package and a factory shroud that I modified to fit the aluminum radiator. My car doesn't have air so it's not apples to apples, just my experience .
Edit** This car has 4.30 gears and a 9.5" 4400 converter.
Re: Still running hot in traffic with the new aluminum rad [Re: justinp61] #231996
03/08/09 09:11 PM
03/08/09 09:11 PM
New York
K
Ken25 Offline
Ken25  Offline
K
New York
the fan used on my 440 is a dual fan off a caravan run off a thermo switch.it fit up to my truck rad pritty good and in 90 deg. heat it could idle all day with no problem.i believe my pump is a mildon hi flow. that might be doing the trick for me
Re: Still running hot in traffic with the new aluminum rad [Re: JohnRR] #231997
03/08/09 09:19 PM
03/08/09 09:19 PM
USA
CrAlt Offline
CrAlt  Offline
USA
Stumpy spelled out the electric fan shroud being restrctive , Dartgirl had the same problem with her RR , alum rad , electric fan and a shroud that blocked flow , it idled fine but once you got it moving it would get way too hot because the shroud was forcing the hot air back into the radiator .
Because the stock fan could pull a heck of alot more then that little electric fan. It was prob pulling air from above and below the evap.
Re: Still running hot in traffic with the new aluminum rad [Re: CrAlt] #231998
03/08/09 09:31 PM
03/08/09 09:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The condenser isn't blocked up.The picture makes it look bad but it's not. There is a good deal of room between the radiator and the condenser and there is space between the cooler and condenser. There is also plenty of air flow through the grille and under the bumper. He also has a air dam that is directing air up into the front. Air to the radiator isn't his problem. The radiator has a shroud that covers at bunch of the back side and leaves air through the fan area only. As I said earlier the fan housing has very close ribbing that cuts down a bunch on air flow.. That is a big restriction.
AHall please post a better picture of the engine side of the radiator and fan for clarification. One more directly at it instead of from the side.
Re: Still running hot in traffic with the new aluminum rad [Re: stumpy] #231999
03/08/09 09:53 PM
03/08/09 09:53 PM
USA
CrAlt Offline
CrAlt  Offline
USA
Or just do what johnrr said and let us know how it worked out
