Stainless intake bolts for alum intake?
#2319654
06/12/17 12:59 AM
06/12/17 12:59 AM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I am wanting to use stainless bolts to bolt my 6 pack on the charger 440 Do they make a stainless bolt with a captive washer sorta like the orignal seat? The reason is I can't stand a rusty bolt on a nice motor Right off I don't the size. Thread count or the length they need to be
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Stainless intake bolts for alum intake?
[Re: toplescuda]
#2319662
06/12/17 01:20 AM
06/12/17 01:20 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
I was hoping for either a bolt with a captive washer or. A head with a wide shoulder (like a washer?) Would also like to use them to bolt the carbs on
[Re: toplescuda]
#2319665
06/12/17 01:25 AM
06/12/17 01:25 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
The intake bolts do require use of a washer. Use a separate washer (hardened washer if you can get them in stainless). Also, the bolts were known to back off and create intake leaks because of differential expansion between the aluminum intake and the steel bolts. The fix was a gasket on each side of the intake pan gasket (2 paper gaskets to sandwich the pan between the intake and the heads on each side).
[Re: toplescuda]
#2319669
06/12/17 01:27 AM
06/12/17 01:27 AM
Posts: 22,782 Bitopia
jcc
Bitopia
ARP is going to be my first suggestion, they do make ss shoulder bolt style or reduced head 12pt. Whats the problem with a SS washer? A true captive washer in SS would be a little problematic in regards to galling issues I suspect.
[Re: jcc]
#2319672
06/12/17 01:30 AM
06/12/17 01:30 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just keep in mind most stainless bolts are softer and more prone to breakage so don't over torque them
[Re: toplescuda]
#2319851
06/12/17 01:15 PM
06/12/17 01:15 PM
Posts: 21,854 Kirkland, Washington
Pacnorthcuda
I was hoping for either a bolt with a captive washer or. A head with a wide shoulder (like a washer?) Would also like to use them to bolt the carbs on For carbs I would use studs.
[Re: Pacnorthcuda]
#2319955
06/12/17 03:50 PM
06/12/17 03:50 PM
Posts: 4,461 Michigan
MarkZ
Worthy
Worthy
I was hoping for either a bolt with a captive washer or. A head with a wide shoulder (like a washer?) Would also like to use them to bolt the carbs on For carbs I would use studs. I second this. I used to use stainless bolts on my carb until one the throttle started sticking wide open. The weirdest damn thing I ever had happen to me in the hobby. Full throttle blasts and the butterflies would stick. Turned out to be the torque was uneven on all four corners and the carb body was tweaked. Switched back to studs after that.
