Anyone reproducing sheet metal for '73-74 Chargers? #2318799
06/10/17 04:43 AM
06/10/17 04:43 AM
Planet Earth
RoadRunnerLuva Offline OP
Planet Earth
I recently bought a '73 Charger SE, but it needs some work, body wise.
It needs both door skins, rear lower quarters, and left rocker panel. Does anyone reproduce these parts currently?? Thanks for help on this. smile
Plymouth Makes It!
Re: Anyone reproducing sheet metal for '73-74 Chargers? [Re: RoadRunnerLuva] #2318899
06/10/17 12:28 PM
06/10/17 12:28 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Unfortunately no, although some of those pieces that you are looking for will work from a 71-72 although most will tell you they won't. I installed used rockers from a 71 on my 74 with know problem also in stalled a left rear wheel house from a 72 on my 74.
Re: Anyone reproducing sheet metal for '73-74 Chargers? [Re: 340cpe] #2318987
06/10/17 03:50 PM
06/10/17 03:50 PM
Planet Earth
Planet Earth
Thanks for your reply. Was the wheel house you installed an inner, or was it the outer? Because I also will need to replace those also (outers).
Plymouth Makes It!
Re: Anyone reproducing sheet metal for '73-74 Chargers? [Re: RoadRunnerLuva] #2319189
06/11/17 12:12 AM
06/11/17 12:12 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
It was the assembly both inner and outer. As long as it is a charger 71-4 they will work I promise! Inner are even the same on Coronets. Yes a coronet is a four door but the inner wheel house is the same. I do believe that inners are the same even on Plymouth B-bodies.
Re: Anyone reproducing sheet metal for '73-74 Chargers? [Re: RoadRunnerLuva] #2319472
06/11/17 04:26 PM
06/11/17 04:26 PM
Bellevue,Mich.
Dodge33 Offline
Dodge33  Offline
Bellevue,Mich.
I have a pair of 72 charger wheelhouse for the rear.pm me
Re: Anyone reproducing sheet metal for '73-74 Chargers? [Re: Dodge33] #2320100
06/12/17 07:24 PM
06/12/17 07:24 PM
Planet Earth
Planet Earth
PM sent
Plymouth Makes It!
