Auto body Guys-2k Primer Question
#2319228
06/11/17 01:19 AM
06/11/17 01:19 AM
Posts: 889 Oh
parksr5
Oh
For the last number of years, I've been working on a truck during the Winters for My Fiance's Father. I've been using the same Limco 800k primer the whole time. This year for some reason, I've had issues some of which I think can be attributed to my gun but, most I think are coming from the temp outside. Most of the time I've worked on the truck it has been cold although, the garage is heated.
The truck is almost done so; I've just been working away this year to wrap up the job. The temp has been in the 70's to 90's.
My issue is the primer is drying before I can even get it on the larger panels which is also clogging my gun.
The primer calls for 4:1 primer to hardener but, using this ratio, the primer is starting to dry and clump up in 5 minutes or less. I've tried using a little less hardener and have also thinned it out but, I'm still having issues with it drying too fast.
I've been cleaning my gun between coats and cleaning out my mixing cup before coats given how fast the stuff is drying but, I can't keep up.
I keep trying different things but, nothing seams to work. Given the primer needs a catalyst, I can't not use the hardener and worry about using less than what is called for.
I've never had an issue with any primer I've used over the years like this.
What else can I do?
Re: Auto body Guys-2k Primer Question
[Re: parksr5]
#2319305
06/11/17 09:37 AM
06/11/17 09:37 AM
Posts: 4,920 new berlin wisconsin
Mr T2U
a quick google search on your primer tells me there re 2 different catalysts for it,810 and 820. i would assume different catalysts for different temps. my guess would be get the WARM temp catalyst and you should be fine. i would recommend keeping it out of the sun when using it also.
on another note if the catalyst is old that could be your problem also. technically speaking after a catalyst is opened more than 30 days. it's not 100% viable anymore and can create problems with cure.
perception is 90% of reality
[Re: parksr5]
#2319511
06/11/17 06:15 PM
06/11/17 06:15 PM
Mr T2U
HOW OLD IS THE PRIMER AND CATALYST. i don't care what you have done in the past. you have never had this problem in the past so what happened in the past doesn't matter now. the data sheet says pot life in 1.5 hours, not 5 min, so something is wrong with the product or the temp you are using it in is to high for the catalyst. i know PPG K36 primer the heat can kick it to jell fast also. you might have to spray in lower temps to get it to work. if the heat is causing the product to gel you don't need to wait 5 min between coats. re-coat immediately after flash off. or you could add a little retarder to slow it down some. or use the slower catalyst, the extended cure times of the other catalyst is longer is because it is designed to be used in higher temps. the gun tip size shouldn't make a lot of difference. the data sheet says 1.5-1.7 tip. if the tip is to small it will just spray really dry. https://www.coatingsmall.com/cap_data_do...LH810_LH820.pdf
[Re: parksr5]
#2319574
06/11/17 10:10 PM
06/11/17 10:10 PM
Posts: 1,637 Florida
GMP440
Are you sure you are at 4:1 on the primer to hardner mix? How did you measure it. Eye ball it or use a mixing cup? From the sound of it you might have put in a little more hardner in the mix. I had the same problem a few months ago , using 2 K primer. I eyeballed the amount hardner and I was off on the ratio , causing the mix to harden sooner. Got a paint mixing cup, measured exactly 4:1 proportion and it hardened much slower on the 2nd go around. I also added a little reducer for better flowout. Everything came out great the 2nd time. By the way, I used a medium temp hardner.
[Re: parksr5]
#2322966
06/18/17 10:57 AM
06/18/17 10:57 AM
Mr T2U
you are probably correct on the hardener and temps. i think that was my second suggestion after old products shelf life.
with urethane products technically the catalyst is bad 30 days after it's opened.
old products can react in unusual ways. i have used 5 year old products without problems and used 30 day old ones and had problems. urethane products can react to high temps and humidity so proper solvents for the temp it's used in is important. sometimes the primer solvent or hardener solvents evaporate while sitting on the shelf if the lid isn't put on properly. if enough solvents evaporate you can over catalyze without knowing it.
