Re: Still running hot in traffic with the new aluminum rad
[Re: gtx69]
#231920
02/22/09 05:08 PM
02/22/09 05:08 PM
Posts: 423 DFW Texas
AHall
DFW Texas
How was the electric fan set up to come on at what temp?
got it wired to run anytime the car is on.
[Re: gtx69]
#231922
02/22/09 07:42 PM
02/22/09 07:42 PM
AHall
DFW Texas
Ok, I just got back from 2 hours of working on the car. Oreillys didnt have a timing gun or vacuum gauge (go figure) so I got the 3 gauge pod. I hooked up the voltage meter and man my alternator is kicking some amperage out. (14) I started the car, took a piece of paper and put it down in front of the radiator behind the a/c condensor and boy did it suck it right to the radiator. I then put my hand behind the radiator and that fan is sucking HARD! ALOT of air is being pulled out of the radiator-that is for sure. I did put a 180 degree thermostat in there today as well. I fired it up after idling there for about 5 minutes and left the neighborhood and got out on the highway. I drove about 6 miles before turning around. I knew immediately when the thermostat opened because it gradually climbed, then all of the sudden jumped a bit- then came back over. Good news was it just sat there the whole time. I exited and came back thru a neighborhood about 6.5 miles, doing 30 mph and coming to alot of stop signs and no issues whatsoever. Now granted it's 69 degrees outside, that could be playing a huge part but as of that 15-20 min trip no issues whatsoever.
[Re: MMiller]
#231923
02/22/09 07:54 PM
02/22/09 07:54 PM
AHall
DFW Texas
Another question if you guys dont mind me asking-- 1) Where do I install the oil line for the new autometer oil gauge I just purchased? 2) Where do I install the long probe at the end of the line on the new temperature gauge? Ive looked all over the engine block and a bit perplexed. (please have mercy on me, im learning here guys--but do appreciate all the help ) EDIT- Instructions said install both into the engine block. Also, how do i get this nut thru the firewall?
[Re: AHall]
#231924
02/22/09 08:28 PM
02/22/09 08:28 PM
Posts: 4,361 swamps of florida
beepsalot
swamps of florida
to get the lines thru the firewall, use the oval plug just below and left of the steering column, it is the hole that the clutch pushrod would go thru if it was a four gear. you can use any of the bigger holes on the water pump housing,. you will have to use the adapters in the kit. the iol line will hook up to the back of the block. look back there and you will see the electric sending unit, the is another plug on the back, at opposite angle from the sending unit. again, use the adapters. you can pm me with anyquestions. beeps
Just Follow Me Down the Street, You'll Know i'm Up to No Good...
[Re: beepsalot]
#231925
02/22/09 08:39 PM
02/22/09 08:39 PM
AHall
DFW Texas
wow, thanks for the info. Here are some pics I snapped of the area---
Is that where I would input the oil unit?
[Re: beepsalot]
#231926
02/22/09 09:46 PM
02/22/09 09:46 PM
gtx69
super gas
super gas
plug opposite from sending until remove use that hole
[Re: gtx69]
#231927
02/22/09 11:24 PM
02/22/09 11:24 PM
RapidRobert
other than the external gauge addition the only thing that you have changed so far is the stat from a 160 to a 180, correct?. & your temp is OK so far
[Re: RapidRobert]
#231928
02/23/09 04:23 AM
02/23/09 04:23 AM
AHall
DFW Texas
Yes, did ok for that 20 min stint. Only thing is, temp was around 65-70 today, no where near the 100 degrees of true test.
[Re: AHall]
#231932
02/23/09 01:47 PM
02/23/09 01:47 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
There is another plugged hole back there , you could put the gauge in that hole .
[Re: B9ChargerSE440]
#231935
02/23/09 10:13 PM
02/23/09 10:13 PM
RapidRobert
Ahall: holler when the temp hits 100. inquiring minds want to know
[Re: RapidRobert]
#231937
02/24/09 07:46 PM
02/24/09 07:46 PM
AHall
DFW Texas
will do man.
[Re: Curt]
#231938
02/24/09 07:47 PM
02/24/09 07:47 PM
AHall
DFW Texas
I live in Grand Prairie about 5 minutes south of the airport and would be glad to help you with and teach you the hands on stuff. I'm retired so I am available most days. I've been a mechanic for over 40 years so I believe I can get you straightened out. There is a large Mopar club that would be glad to have you join us. CowtownMopars. Here's a link to our site. http://www.cowtownmopars.com/. We average 150 members. We have a race team and a show team. We do cruises and picnics, hold a yearly toy run and generally do a lot of Mopar realated stuff. Our meetings are once a month at Billy Bob's in the stockyards.
My email is, stumpy383@hotmail.com
I don't have a dog in the ring but stop and think....A man that has been doing this FOR A LIVING for over 40 years is offering his help for free (I am sure he was making over $30+ per hour full time) and he is...sounds like... 20 minutes away SHOULD be hard to pass up. He is retired which means it is now car playtime. I bet in an hours time he can have your car running, starting, driving better than it ever has since you have owned it. And in that same hours time you could have at least 30 questions answered and be well on your way to a set of proud greasy, busted up hands. There is nothing like the sensation of the light bulb being switched on... Curt
AMEN to what you said. Already arranged and cant wait for Stumpy to come over Saturday morning.
