Shave part of a firewall (ebody)
#2318341
06/09/17 03:19 AM
06/09/17 03:19 AM
Posts: 138 Los Angeles, CA
71_dramaqueen
Los Angeles, CA
Looking for some bodywork advice for to the best way to shave part of a firewall (for this e body). I will be installing a vintage air system so i do not need all the holes for the old plumbing. Would i be best off welding a "patch" sheet over the area marked in red and using filler to blend it in? Or put the patch on the inside of the firewall and weld the holes flush to it then filler holes. Or cut out and weld flush pieces for each hole individually? thanks
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: Shave part of a firewall (ebody)
[Re: dvw]
#2318403
06/09/17 11:12 AM
06/09/17 11:12 AM
Posts: 306 Georgia
69bfan
Georgia
If you are wanting to use accurate fitting laser cut plugs to fill these holes, we have made up kits for the B and E-Body applications. The original intent was for those people wanting to use an AC firewall in a non AC application. But the restomod guys have been buying these kits to slick the firewalls up. If you need more information, drop me a message.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: 69bfan]
#2319598
06/11/17 11:13 PM
06/11/17 11:13 PM
71_dramaqueen
Los Angeles, CA
This right here is one of the reasons this forum is awesome. I never would have guessed pre-cut firewall fillers existed. How do i order?
The ebody firewall has several bends that would making one big bended patch difficult i think.
[Re: 71_dramaqueen]
#2319619
06/11/17 11:52 PM
06/11/17 11:52 PM
Posts: 306 Georgia
69bfan
Georgia
We initially made these precut fillers before reproduction firewalls were available. If someone had a nice AC style firewall and wanted to make it into a non AC style firewall, this allowed someone the opportunity to use the kit to avoid having to cut the sheet metal and the slugs fit tightly to minimize the welding required. With the number of people doing resto mods, we are now selling more to this market as many do not want to completely cut out the firewall. We made the kits for the 66 to 70 B-Bodies and 70 to 74 E-Bodies. I sent you a private message with my contact information.
