Tach wiring location #2318323
06/09/17 01:52 AM
06/09/17 01:52 AM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
I have a customer that wants a tic-toc-tach installed in his '69 Charger. He has the two harnesses (engine and dash) for the tach. The dash harness has a 1" grommet on it where it is supposed to go thru the firewall.
Does anyone have a picture of the exact location where I have to put the hole? There are a couple of "dimples" up near where the headlamp vacuum harness comes thru. I'm presuming it must be near these. Thanks...
Re: Tach wiring location [Re: superwrench] #2318516
06/09/17 03:18 PM
06/09/17 03:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
From a previous post:
Re: Tach wiring location [Re: John_Kunkel] #2318551
06/09/17 05:00 PM
06/09/17 05:00 PM
SE Pa.
LimeliteAero Offline
SE Pa.
referencing the above photo there should be a dimple in the firewall where that gromet is.
Re: Tach wiring location [Re: superwrench] #2318720
06/09/17 11:09 PM
06/09/17 11:09 PM
Yes..there is a dimple there...Thanks to all !!
