Using a canton oil filter sandwich adapter, do I need to use a non bypass filter, or any other special filter?
I have installed it and a large oil cooler yesterday, and noticed pressure to be slightly lower. Although it's a big cooler, 7x14 20 row. Didn't know if a 5-8psi drop was normal for a big cooler and -10 lines maybe? I also noticed pressure isn't as responsive with rpm, it rises with rpm, just not as fast as without the cooler.
