Re: What are these holes in my intake manifold?
[Re: r3dplanet]
#2317317
06/06/17 09:19 PM
06/06/17 09:19 PM
RapidRobert
that is the sideways heat riser passage. not sure what device goes in those 2 holes but yes it would emit exhaust/oil fumes.
[Re: r3dplanet]
#2317336
06/06/17 09:51 PM
06/06/17 09:51 PM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
Is that something for a mechanical choke? <no idea>
The oil pooling might be caused by oil traveling up the threads of the intake bolts. I've had it happen a few times when I still had a small block. RTV on the threads cures it.
[Re: 62maxwgn]
#2317540
06/07/17 10:18 AM
06/07/17 10:18 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Some of the first Edelbrock CH4B intakes had a hole in the exhaust cross over for heat tube to the choke housing mounted on the carb. On what? A chevy? Cause the choke housing on a MoPar is in the intake and there is no heat tube. The only MoPar intake I am aware of that uses heat tubes is the long horn cross ram set up and you will never see one of those o a 360.
[Re: Supercuda]
#2317600
06/07/17 12:37 PM
06/07/17 12:37 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Some of the first Edelbrock CH4B intakes had a hole in the exhaust cross over for heat tube to the choke housing mounted on the carb. On what? A chevy? Cause the choke housing on a MoPar is in the intake and there is no heat tube. The only MoPar intake I am aware of that uses heat tubes is the long horn cross ram set up and you will never see one of those o a 360. I'm not talking about a 360,don't know about that manifold but all Chrysler in line 2x4 engines be it 361/383/413 used a exhaust manifold heat tube to the choke housing as do the Hemi,the early CH4B had that provision from the heat cross over instead of from the exhaust manifold.I would "assume" all after market intakes of that period could have that provision as the manufacturer would have no idea of what a customer would use as a fuel system and that would cover using a carb with a heat tube is the person chose that route.
[Re: 62maxwgn]
#2317642
06/07/17 02:20 PM
06/07/17 02:20 PM
Supercuda
About to go away
About to go away
up yours
Then why bring it up? We aren't talking about big blocks, we aren't talking about dual inline setups. Useless information to confuse people. And [ Moparts Family Site - Keep it Friendly ] is that picture supposed to be of? I see no intake.
[Re: Supercuda]
#2317719
06/07/17 04:46 PM
06/07/17 04:46 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some of the first Edelbrock CH4B intakes had a hole in the exhaust cross over for heat tube to the choke housing mounted on the carb. On what? A chevy? Cause the choke housing on a MoPar is in the intake and there is no heat tube. Aftermarket manifolds are required to follow the factory choke format? One hole could be for a clean air source and the other supplies heated air for the choke.
[Re: r3dplanet]
#2317797
06/07/17 08:56 PM
06/07/17 08:56 PM
Posts: 294 Maryland
MoparMike1974
Maryland
Most mopar small blocks used a bi-metal spring to work the choke. It did not use a gas tube (Ford did if I recall). The stock intakes had a cup cast into it and it basically functioned off radiant heat. Much better design than those gas tubes that leak and plug up. I say most because im not familiar with the older stuff like the old 318 wide blocks and anything pre 65.
[Re: r3dplanet]
#2317878
06/07/17 11:43 PM
06/07/17 11:43 PM
Posts: 3,391 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Mybig block Weiand intake had a similar hole thingy, but it was on the underside of the heat riser, facing down at the valley pan. Like yours, it almost looked like it had a small roll pin shoved into it.
Never leaked or had an issue with it though.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: r3dplanet]
#2317896
06/08/17 12:14 AM
06/08/17 12:14 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Heat source for choke and most likely not the source of your odor. Unless you or a previous owner drilled down into them they are blind holes from the Weiand factory, in fact the inboard one is probably more of a dimple than a hole.
You can tap the outer hole and and attach a type of divorced choke commonly found on Q Jets of other brands. The inner hole probably would need to be drilled either to tap into a cast passage or heat pipe run through the base of the intake casting. My LD340 on the shelf has a small heat pipe running from one side to the other. Not sure what the stealth has because I'm not going to pop it off the engine or take a drill to it to satisfy my curiosity.
Have you probed the holes to see if they go anywhere? I doubt they do. If either had hot exhaust pouring out of it it would be discolored or soot stained around the hole opening.
Here are the same holes on the stealth intake I bought new. Inboard is a just a dimple outboard is about 1/2 inch deep blind hole.
Also pics of the same "holes" visible beside the carburetor pad on a big block edelbrock, and an LD340 with the q-jet divorced choke added and one without.
Guess back when they first cast these manifold its was cheaper or faster to make a provision for the brand x choke than molding a proper cup for mounting for one of the factory style chrysler chokes.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: B5 Bee]
#2317902
06/08/17 12:26 AM
06/08/17 12:26 AM
Michael Ecks
Columbus, GA
I doubt the OP's intake in question was drilled by Weiand. It's too new. The Stealth series didn't come out till 1990-1992 or so. Actually if you look up the SBM stealth on summit you can see those holes in the stock photo.
[Re: Supercuda]
#2317940
06/08/17 02:51 AM
06/08/17 02:51 AM
62maxwgn
Blair County,PA
Then why bring it up? We aren't talking about big blocks, we aren't talking about dual inline setups. Useless information to confuse people. And [ Moparts Family Site - Keep it Friendly ] is that picture supposed to be of? I see no intake. That is a 62 300H carb,same as Hemi that requires a heat tube source for the choke,I guess we are talking about two different heat tubes.As for why bring it up,there are applications other than long ram that you stated is the only one require a heat tube of some configuration,the OP ask about the hole in the intake,I merely stated that the early Edelbrock and possibly others had a provision for manifold heat for the choke,and the [ Moparts Family Site - Keep it Friendly ] wasn't necessary !!
