Re: Electronic Ignition Conversion
[Re: Lugnutz]
#2317093
06/06/17 12:14 PM
06/06/17 12:14 PM
RapidRobert
An option would be everything from a boneyard: a 70's low deck dist/ECU pentastar connector with a foot of pigtails. keep your current coil/ballast & get a 4 pin ECU from your parts house (& a spare). Ebay would also have the connector/pigtails new if need be.
[Re: Lugnutz]
#2317228
06/06/17 06:19 PM
06/06/17 06:19 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I think the Pertronix is the best bang for the buck. When used with their coil, no ballast is needed which simplifies the installation.
[Re: Lugnutz]
#2317252
06/06/17 07:06 PM
06/06/17 07:06 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
Another vote for Pertronix. Definitely the cheapest, easiest option. If you take your time installing it you can even hide the extra wire and keep the stock look.
No longer taking $h!t from anyone!
[Re: dogdays]
#2317302
06/06/17 08:56 PM
06/06/17 08:56 PM
RapidRobert
Dog are you SURE you ain't got any left!
[Re: DUFFMAN]
#2317371
06/06/17 10:52 PM
06/06/17 10:52 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Another vote for Pertronix. Definitely the cheapest, easiest option. If you take your time installing it you can even hide the extra wire and keep the stock look. I have always had great luck with Pertonix conversions, all i recommend is if you go with that set up, buy 2 units and keep one in the car just in case the one in distributor goes bad on the road. Murphy's Law in action! Stu
