Re: Drop spindles; your experience? [Re: geo.] #2316726
06/05/17 06:20 PM
06/05/17 06:20 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Originally Posted By geo.
Originally Posted By John_Kunkel
One problem with dropped spindles is that they place the lower control arm closer to the ground, you'll run into things you normally wouldn't.
Yes!!
With 15" wheels, No drop spindles!
Maybe with 18" or larger wheels,and No headers it might be a good plan.
If I was local to you, I'd want to try those wheels on an E body, but I'd put the 4.5 b.s. ones on the front and swap the tires, I think it would look great!
chassis height will be adjusted with the torsion bar screws. So chassis can remain in same place.
Yes, that side of the LCA will be 2" closer to the ground. But the wheel is there. Guess if you plan on driving over roadkill just to the inside of your tire you could have an issue. Or the very edge of a tall speed bump that's not very rounded. I haven't heard anyone hitting anything. But that doesn't mean much.
Re: Drop spindles; your experience? [Re: Supercuda] #2317057
06/06/17 10:28 AM
06/06/17 10:28 AM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
Nope. It's a good thought but I tried this. Even the 4.5" BS wheels don't clear the QA1 balljoints on the front.
Re: Drop spindles; your experience? [Re: MRGTX] #2317136
06/06/17 01:58 PM
06/06/17 01:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By MRGTX
QA1 balljoints
Are they "tall" ball joints?
Don't be the exception.
Re: Drop spindles; your experience? [Re: MRGTX] #2317186
06/06/17 04:32 PM
06/06/17 04:32 PM
n.c.
geo. Offline
geo.  Offline
n.c.
It sounds like those arms have less clearance than the stock arms. I've used 15x8" Supercoupe wheels on a Challenger with no interference with the upper arms/ball joints.
Compare them with your stock arms, maybe you could carefully grind the tight spots?
Re: Drop spindles; your experience? [Re: MRGTX] #2317232
06/06/17 06:31 PM
06/06/17 06:31 PM
So Cal
So Cal
Something seems strange about this.
What spindles do you have?
Do you have a picture of the interference?
A picture of the uca installed on your car?
You said you drove 100 ft with the 4.93" back spacing and there was some minor scraping. Did you have spacers on those when that happened?
Where exactly on the rim did it scrape? Where on the UCA?
So the 4.5" was the exact same? With spacers?
Re: Drop spindles; your experience? [Re: MRGTX] #2317578
06/07/17 11:49 AM
06/07/17 11:49 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I have seen differences on ball joint stud length on stock replacement joints especially if they are made overseas.
Carl Kessel
Re: Drop spindles; your experience? [Re: MRGTX] #2317598
06/07/17 12:32 PM
06/07/17 12:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you look at circle track stuff you can get tall upper ball joints for MoPars, some of them made by QA1, I suspect this might be it.
As an example
Re: Drop spindles; your experience? [Re: Supercuda] #2318538
06/09/17 04:13 PM
06/09/17 04:13 PM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
They do appear to be slightly taller than the stock ones...I bought them based on good feedback on the quality of the arms.
Re: Drop spindles; your experience? [Re: MRGTX] #2318557
06/09/17 05:36 PM
06/09/17 05:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
QA1 does make good ball joints, but if the stock replacement type is short enough to let your rims work...
Well that's a cheap solution.
Re: Drop spindles; your experience? [Re: Supercuda] #2319883
06/12/17 01:53 PM
06/12/17 01:53 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Way off here, but for reference I used 3" drop spindles on my 77 Chev truck in the pic...
Used a 4" drop kit on the rear...
