Msd sbm dizzy... rotor doesnt line up with shaft #2316971
06/05/17 11:57 PM
06/05/17 11:57 PM
Dirty Dena, Maryland
dodge turbo Offline OP
Seeing if anyone else has locked out a pro billet and noticed the shaft doesnt line up with fhe rotor button.
Whats was the fix?. Trying to line it up with #1 at tdc
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Msd sbm dizzy... rotor doesnt line up with shaft [Re: dodge turbo] #2316976
06/06/17 12:28 AM
06/06/17 12:28 AM
with the magnet lined up with a tooth (ready to fire) is the rotor pointing at or very near at a dist cap terminal post bulge (dead on with the terminal). If I am reading this right, the bottom tang does not need to be clocked parallel to the rotor, the first sentence is the bottom line. Holler back.
Re: Msd sbm dizzy... rotor doesnt line up with shaft [Re: dodge turbo] #2316982
06/06/17 12:40 AM
06/06/17 12:40 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
IIRC you have to take the bushing screw out, turn the shaft 180 degrees and then you can bolt it for lock out. I think that you have to punch out the roll pin at the bottom so the shaft will slide up into the dis. to allow the 180 degree rotation.
Re: Msd sbm dizzy... rotor doesnt line up with shaft [Re: dodge turbo] #2317038
06/06/17 07:29 AM
06/06/17 07:29 AM
I did take it apart per msd instruction and turned it 180 and thats how
It ended up.
Yea i can get it to line up with a post. I was worried about lining the tang up with cylinder 1 and the number 1 plug alligning while at TDC as you would with a stock one.
Re: Msd sbm dizzy... rotor doesnt line up with shaft [Re: dodge turbo] #2317040
06/06/17 07:34 AM
06/06/17 07:34 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Depends on where the #1 plug wire tower on the cap locates. Hopefully in line with the rotor.
[image][/image]
Re: Msd sbm dizzy... rotor doesnt line up with shaft [Re: dodge turbo] #2317041
06/06/17 07:37 AM
06/06/17 07:37 AM
LIKe this.... the rotor button does not line up with the shaft direction.
Re: Msd sbm dizzy... rotor doesnt line up with shaft [Re: dodge turbo] #2317065
06/06/17 09:55 AM
06/06/17 09:55 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Move the intermediate shaft so that the rotor is pointed where you want it to be pointed.
Tony
70 AARCuda Vitamin C
Re: Msd sbm dizzy... rotor doesnt line up with shaft [Re: 70AARcuda] #2317098
06/06/17 11:23 AM
06/06/17 11:23 AM
& best SB clocking is with the dampener on your initial (say 15 BTDC #1 firing) & magnet lined up with the tooth that the rotor is pointing forward & slightly to the pass side. this lets the plug wires nestle the neatest with the shortest lengths possible. Not a dealbreaker by any means but every little bit helps.
Re: Msd sbm dizzy... rotor doesnt line up with shaft [Re: dodge turbo] #2317102
06/06/17 11:29 AM
06/06/17 11:29 AM
Washington
madscientist Offline
Washington
It doesn't matter which way the shaft points. I've seen very few that line up with the rotor. I'd bet I have 10 distributors in the shop and not one lines up.
Turn the drive so the slot points in the direction to make the rotor point to number one on the cap. Drop it in.
