Re: 70 Cuda - Rolling Resistance Issue
[Re: 70GranCoupe]
#2315767
06/03/17 11:51 PM
06/03/17 11:51 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Check and see how easy the driveshaft turns when the rear tires are off the ground, and trans out of gear, motor turned off. Maybe the rear end gears, or bearings, are too tight. And check the rearend temp after driving it awhile. For the heck of it, also check the transmission's temp after driving it for awhile.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2315770
06/03/17 11:56 PM
06/03/17 11:56 PM
amxautox
If the driveshaft turns hard, remove it from the car. Then check how easy the rearend yoke turns, and how easy the transmission output shaft turns, and go from there.
Tom
author unknown
[Re: 70GranCoupe]
#2315776
06/04/17 12:07 AM
06/04/17 12:07 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
A little more back ground is needed, did you just buy the car? Was anything swapped out ? engine , trans , drive shaft or rear? How about the converter?
[Re: 70GranCoupe]
#2315883
06/04/17 11:49 AM
06/04/17 11:49 AM
Posts: 5,967 ohio
ruderunner
ohio
Bias ply tires? They do have more rolling resistance compared to radials. Don't think it could be that much difference though.
Perhaps overinflating the tires and seeing what happens could shed some light.
Also, sounds like yo may have just done a couple shake downs drives, has the front end been aligned yet? Out of spec toe can add lots of drag.
Angry white pureblood male
[Re: 70GranCoupe]
#2315947
06/04/17 02:03 PM
06/04/17 02:03 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
What is accurate engine rpm speed in drive, in neutral, not just what dash tach says. What are torque converter specs? Linkage to carb all ok?
When driving on level, place trans in neutral and let coast down. Does deceleration appear normal?
Place on very slight incline in neutral, no emergency brake. Will car begin to move on its own when you release foot brake?
[Re: 70GranCoupe]
#2316031
06/04/17 04:45 PM
06/04/17 04:45 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I have a 70 Cuda, 440, 727, 3.23 SG, power front disc brakes. When I drive the car the initial movement forward or reverse is very stiff, and I have to give it a fair amount of gas to move. Car will not idle forward if I take my foot off the brake when it is in gear. Something is holding it back. It is as if the brakes were on, however the wheels rotate smoothly when I lift it off the ground and the brakes are not hot after driving it for a while. So I do not not think it is a brake issue. Same with transmission as it is in both forward and reverse gear. Although I could be wrong. Any suggestions as to what this can be. Appreciate it. If you've eliminated the wheels and brakes as the frictional source, can you push/move the vehicle freely with it in neutral/engine not running? If not then I'd be looking at driveshaft/rear diff/axle as the source, if you can confirm these rotate freely and the condition is only when the engine is running and or in gear, then I'd be looking at either the brake booster to master pushrod adjustment as that may be inducing front residual brake drag, if that has been eliminated, my next suspect would be that the transmission band adjustment may be too "tight", I'd start with the 1st/rev band and re-torque/adjust to factory/mfg recommended specs, check the 2-3 band as well, you'll need to drop the pan for 1st/rev band adjustment... Mike
