8 3/4 dimension question #2315411
06/03/17 12:54 AM
06/03/17 12:54 AM
MN
58pwrwgn Offline OP
58pwrwgn  Offline OP
MN
I have a e-body axle that someone moved the spring perches to 44 inches. Is this the correct distance if you were the use offset hangers and shackles. Or????
Re: 8 3/4 dimension question [Re: 58pwrwgn] #2315692
06/03/17 07:22 PM
06/03/17 07:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on who makes the offset kit but 44" is pretty common for E-bodies. (One inch offset on each side.)
