Re: Brad penn
[Re: 1980volare]
#2315360
06/02/17 10:53 PM
06/02/17 10:53 PM
Posts: 643 southern conn
1969gtx
southern conn
brad penn has sold I'm told same product so summit states just got 2 cases of break in oil sill green ?
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
Re: Brad penn
[Re: 1980volare]
#2315422
06/03/17 01:16 AM
06/03/17 01:16 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
This is not a warm fuzzy as I was preparing to buy Brad penn break in lube for a new build that I'm doing.
So is it still suitable as a break in lube?
**Photobucket sucks**
Re: Brad penn
[Re: 70Cuda383]
#2315442
06/03/17 02:03 AM
06/03/17 02:03 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
So is it still suitable as a break in lube? This is why I don't jump on the bandwagon w/all of this wazoo bs..........Valvoline has been around longer than most along w/others and has been in some fast long lived rides so between Valvoline and Mobile-1, most anyone's needs can be met............
Re: Brad penn
[Re: Thumperdart]
#2316509
06/05/17 11:25 AM
06/05/17 11:25 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
So is it still suitable as a break in lube? This is why I don't jump on the bandwagon w/all of this wazoo bs..........Valvoline has been around longer than most along w/others and has been in some fast long lived rides so between Valvoline and Mobile-1, most anyone's needs can be met............ Seems like motor oil and ignition products always have that "snake oil salesman" vibe.
Re: Brad penn
[Re: 1980volare]
#2316651
06/05/17 03:49 PM
06/05/17 03:49 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
You would be very surprised to see what differences there are in some of the oils, or maybe better stated, what ISNT true about some of the marketing claims. I have been fortunate to get a look at some testing done by some people involved in NASCAR shops, and do nothing but study and test oils. There absolutely IS different results and characteristics of many of the common named oils, and more so, the higher level racing oils.Most people dont see the difference, because they simply arent necessarily stressing the limits of the oils, so the off the shelf stuff will always work, and thats fine, as there isnt any real need for anything different. Often times , these users change the oil enough, where its not really a big deal. When you really want to see what an oil is all about, put it in a high RPM circle track engine, or boat motor. I recently witnessed a 20* temperature difference between two oils, straight up, change oil, temps dropped. A " common" off the shelf oil, was replaced with a higher end oil, and the results were exactly that. When you run for upward of 30 minutes, especially on a dirt track, where clay starts to interfere with cooling access, and flow, things happen fast at higher RPMs. I also saw a trick to reduce oil temps with a simple 10 minute procedure while building a engine.Oil temps lowered. Some of the parts manufactures also get into oil testing, such as with hydraulic lifters and such, where the weight of the oil is even a big deal. These people that test this stuff are very smart, have the knowledge, and the testing facilities, and more importantly, the hard data to compare.A recent test of the new CK diesel oils really showed a problem with flat tappet cams....its real world stuff. trust me.
My point is, there IS a huge difference in a box store oil, versus some of the race brands. The reality is, not every situation will benefit from it.Where those benefits may be noticed, might not matter in many of the engines we are talking about. I will stick with what I am comfortable with, and works, always based on research and input from some very sharp and experienced people.
My two cents.
RIP Monte Smith
Re: Brad penn
[Re: Thumperdart]
#2316812
06/05/17 08:10 PM
06/05/17 08:10 PM
Posts: 4,457 Washington
madscientist
Washington
I suppose you can't "spill the beans" about these oils............ He did spill the beans. He said COMMON oils. The ones you can buy at the store. I have to order the oil I use. Last I looked, it's about $20.00 per quart. I pay that willingly.
Re: Brad penn
[Re: Thumperdart]
#2316833
06/05/17 08:43 PM
06/05/17 08:43 PM
madscientist
Washington
You can buy Mobile-1 and the supposed new Pennzoil they put in the "high end" cars of today in stores.............Do those not stack up? Most of the time they are good enough. Are they THE best? Probably not.
Re: Brad penn
[Re: wyoming]
#2316853
06/05/17 09:23 PM
06/05/17 09:23 PM
Thumperdart
State of confusion
Heard it was Kendall w/additives..............
Re: Brad penn
[Re: Thumperdart]
#2316899
06/05/17 10:51 PM
06/05/17 10:51 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Heard it was Kendall w/additives.............. Dom, Not likely. Comparing the spec sheets for Brad Penn's oils and the ones for Kendall and they're different products. Like most theories, there's possibly some bits of truth in them. For example I know that Brad Penn and Kendall can be had from the same distributors. They might even be part of the the same company; I don't recall and don't care enough to look. It's also possible they use some of the same base stock or blending facilities, however I don't think so. Brad Penn had their own facilities. However, a lot of 'brands' have their oil blended and labelled at the same facility but that doesn't mean they're the same. IMO it is better to compare specific oil rather than Brands. Sometimes a brand doesn't have the oil characteristics we want. Then keep looking. Also within bigger brands, like Mobile 1, there are often a variety of oils available. Some for extended miles, some for high milage, another for Euro-truck specs, etc. Even with the same SAE grade, the viscosities, the detergents, and additives can be different. Fortunately, most of the companies have spec sheets available; and for those really into the tech, people sometimes post Virgin Oil Analysis (VOA) results on forums. If you're interested in the subject, check out Richard Widman's paper. Download the pdf from his Corvair page http://www.widman.biz/Corvair/English/Links/Oil.htmlHe doesn't get into specifically into racing but provides all the info needed to figure it how cold or high temperatures, pressures or changes in bearing clearences can change things.
Re: Brad penn
[Re: Thumperdart]
#2316908
06/05/17 11:24 PM
06/05/17 11:24 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Heard it was Kendall w/additives.............. Kendall Oil has been bought/sold several times in the last 15+ years. It started when they merged with Amalie Oil. Eventually they became part of Conoco-Phillips. Kendall dropped the "green" GT-1 when the Amalie/Kendall parent corp sold the Bradford refinery to American Refinery Corp, the makers of Brad Penn. So no, Brad Penn is not Kendall GT-1 with additives.
