Torque converters.
#2314554
06/01/17 01:37 PM
06/01/17 01:37 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'd like to hear input you guys have on brands of torque converters that you like and ones to stay away from.
383 with heads, 10-ish compression, cam. I think I want something up around a 2800-3000 flash, but has very minimal slip at light throttle cruise. Also looking for economical. I don't want a cheap unit that stalls all the time, but also don't want a $1200 converter. The car is just a cruiser.
I know vehicle weight and engine torque will play into actual stall RPM. But I don't have those figures. It's a 68 roadrunner but cam has not been selected. I'd like to target around 425 crank hp with good street manners and torque. It's got manual brakes so vacuum isn't an issue, but I know I can't go too crazy with a cam without also doing gears and killing the overall drivability.
Anyway... asking about converter brands. Should I be shopping from a trans guru or are the off the shelf stuffcat Jegs/summit good choices?
**Photobucket sucks**
Re: Torque converters.
[Re: 70Cuda383]
#2314566
06/01/17 02:00 PM
06/01/17 02:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm running a Ultimate fr0om Lenny in my street rod.. I wanted something with a bit more stall, I'm at about 4500 and I am running a 4.10 gear with a 518 OD trans with 570hp and it seems to work the way I want.. I also have 3 TA converters which have been great and I also have Trans Specialties and a Coan.. the last 2 dont trill me
[Re: fast68plymouth]
#2314681
06/01/17 04:47 PM
06/01/17 04:47 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I was told that Summit and Jegs least returned items are B&M converters
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 70Cuda383]
#2314879
06/01/17 11:07 PM
06/01/17 11:07 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I've always used ATI, but Quickdraw and Perfect converter company are both used a lot in this area.
[Re: nss guy]
#2314881
06/01/17 11:10 PM
06/01/17 11:10 PM
dartman366
Mt. Vernon, Ohio
You might try Quickdraw, I think he is out of the Newark, Oh area. Lots of local racers have had good luck with him. If you need it adjusted he's local X2 on Quickdraw, he built one of his billit case racing converters for my 904 and it has worked flawless, he is also the only guy that if you take a converter to he will cut it open while you are there and inspect it and tell you what you need and will quote a price so you know what to expect.
[Re: 70Cuda383]
#2314918
06/02/17 12:21 AM
06/02/17 12:21 AM
70Cuda383
Marysville, O-H-I-O
Thanks. I'll have to check out QuickDraw. Never heard of them before... but there was once a time where I had never heard of kammer and kammer in Dayton too
[Re: quickd100]
#2315056
06/02/17 12:12 PM
06/02/17 12:12 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
I have two Turbo-Action converters redone by Lenny at Ultimate and he redid the lockup converter for my the 518 in my D150 all work great. Coan boned my buddy on a trans A few years ago , I would never use or recommend them.
[Re: 70Cuda383]
#2315057
06/02/17 12:13 PM
06/02/17 12:13 PM
Posts: 4,209 New York
polyspheric
New York
You can't buy a converter until you have the engine data, especially the cam, and stock power + 100 (425) needs more than a cam.
Boffin Emeritus
[Re: 70Cuda383]
#2315066
06/02/17 12:37 PM
06/02/17 12:37 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Get a solid engine plan in place to give a converter builder a decent shot of doing it right. You are right to figure on a mild cam. Focus on head work and other engine parts to build a strong motor with a mild cam. A solid lifter cam will have an edge over a hydraulic. A converter with stall high enough to get well into the torque band will be more forgiving if you want taller gears for cruising.
[Re: polyspheric]
#2315204
06/02/17 05:38 PM
06/02/17 05:38 PM
70Cuda383
Marysville, O-H-I-O
You can't buy a converter until you have the engine data, especially the cam, and stock power + 100 (425) needs more than a cam. I know it needs more than a cam. It's getting fully rebuilt. Aluminum heads, higher compression pistons, better intake, better carb, headers, etc. I have no doubt a free flowing 383 couldn't make 425 crank hp.
[Re: 70Cuda383]
#2315235
06/02/17 06:43 PM
06/02/17 06:43 PM
Thumperdart
State of confusion
You can't buy a converter until you have the engine data, especially the cam, and stock power + 100 (425) needs more than a cam. I know it needs more than a cam. It's getting fully rebuilt. Aluminum heads, higher compression pistons, better intake, better carb, headers, etc. I have no doubt a free flowing 383 couldn't make 425 crank hp. Falling out of a tree............
[Re: 70Cuda383]
#2315450
06/03/17 02:27 AM
06/03/17 02:27 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I use a Luppo Dynamic and it has worked great for me for 11 years so far. Also have used Turbo Action with great results. Ron
