Shopping for lifters....offset, pushrod oiling. #2314367
05/31/17 11:14 PM
05/31/17 11:14 PM
Bellevue, NE
Charger453 Offline OP
Bellevue, NE
Since we've learned you can't trust the manufacturer's description, I'm looking for some part #'s.
I'm running .462/.430 lobe lift in a non-bushed factory block. I'm running 440-1s on a low deck and I currently have Comp 892s. I'm hoping to find something with the same, or very close, pushrod seat height of 1.91. I want an offset intake lifter and I need pushrod oiling. My car sees a fair amount of street time for what it is.
What's the best solid roller lifter out there in the $600-$800 range?
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314396
05/31/17 11:59 PM
05/31/17 11:59 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Dumb question probably. What's the problem with the 892s you have?
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314414
06/01/17 12:35 AM
06/01/17 12:35 AM
Bellevue, NE
Bellevue, NE
The oiling hole intersects with the main oil galley. Per Comp's recommendation to others, I restricted the oiling with jbweld. I'm all the way down to a .014" hole on the galley side and the other hole is totally blocked off. I don't trust this long-term in a "street car".
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314561
06/01/17 01:51 PM
06/01/17 01:51 PM
Bellevue, NE
Bellevue, NE
And I'm here for first-hand experience because the manufacturers don't even know what they have. Crane has their ultra-pro listed as pushrod oiling and they aren't. Comp had some lifters listed as edm oiling to the roller and they aren't.
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314577
06/01/17 02:14 PM
06/01/17 02:14 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Contact Scott Brown. Buyracingparts.com
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314602
06/01/17 02:55 PM
06/01/17 02:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I personally run Isky solid body lifters and have for MANY miles and years w/one rebuild............680-.660 276-281 solid roller street car........ beer
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314701
06/01/17 05:27 PM
06/01/17 05:27 PM
Bellevue, NE
Bellevue, NE
It looks like Isky has what I need. Unfortunately they are $1079, but I'm to the point where I'll spend it. Allegedly the BAM lifters work, but I'm having a hard time seeing how they would be much different since they also have the oiling hole perpendicular to the axle. They don't have the cutaway, but they do have a large hole on the same side, right below the oiling hole.
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314719
06/01/17 06:09 PM
06/01/17 06:09 PM
AndyF Offline
AndyF  Offline
I had the same problem with Crower lifters. They told me they would work but they didn't. A lot of folks on the tech lines don't know what works in a Mopar.
The offset lifter is a bit of an issue. For non offset lifters I just use the AMC roller lifters from Comp. They are inexpensive and they work just fine for most applications.
If I needed offset lifters I'd probably see if Morel has anything that would work.
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314737
06/01/17 06:55 PM
06/01/17 06:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Those must be the Red-Zone's mine are the basic needle bearing pieces but the RZ's should last damn near forever...........
thumbs
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314784
06/01/17 08:33 PM
06/01/17 08:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run the Isky's. It hurt a bushing in one last year after 80 passes. Don't know why. I sent all 16 back. Only that one was bad, they fixed it at N/C. Haven't had any issues since. Lash never varies on checks more than .001" on 2-3. 320/810 spring pressure.
Doug
Re: Shopping for lifters....offset, pushrod oiling. [Re: Charger453] #2314923
06/02/17 12:32 AM
06/02/17 12:32 AM
Bellevue, NE
Bellevue, NE
I'm going to do some search on these BAM lifters and talk to some people that sell them and use them. If I don't like what I hear, it looks like Isky is the way to go.
