Part # for 4 groove crank pulley #2313201
05/29/17 08:57 PM
05/29/17 08:57 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
I am in need a 4 groove crank pulley for a 70 RR.Does anyone know the part# and availability.Is it repopped??Thanks
Re: Part # for 4 groove crank pulley [Re: 70RR383] #2313222
05/29/17 09:21 PM
05/29/17 09:21 PM
I might be able to get you one. I will measure mine & get back to you.
Re: Part # for 4 groove crank pulley [Re: 70RR383] #2313437
05/30/17 10:23 AM
05/30/17 10:23 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I would not buy that pulley in repop even if the made it. Plenty of used ones out there. You'll have to buy it from someone that knows the difference in pulleys is all. They made several versions.
Re: Part # for 4 groove crank pulley [Re: 70RR383] #2313444
05/30/17 10:37 AM
05/30/17 10:37 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Part # for 4 groove crank pulley [Re: 70RR383] #2313447
05/30/17 10:49 AM
05/30/17 10:49 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I have several 4 groove pullies. PM me if interested. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Part # for 4 groove crank pulley [Re: 70RR383] #2313468
05/30/17 11:34 AM
05/30/17 11:34 AM
Minn
SportF Offline
SportF  Offline
Minn
Clay and Son's in Catawissa would have numerous pullies and he is just down the road from you. Good luck.
Let me edit this and say they have about 700 mopars there and you could match up what you need, instead of say, guessing. AND, the stuff is priced to sell.
Re: Part # for 4 groove crank pulley [Re: Supercuda] #2313580
05/30/17 02:48 PM
05/30/17 02:48 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Originally Posted By Supercuda
My point exactly. $150 for a pulley when I bet there are 100 guys on this board who have them lying around collecting dust and would sell you one shipped for $50 or less. The one you need has the outer pulleys slightly smaller than the two inner ones. If my memory serves me correct. I'm not at the shop so I can't look.
Re: Part # for 4 groove crank pulley [Re: 70RR383] #2313611
05/30/17 03:40 PM
05/30/17 03:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Pulleys gotta work with each other.
Bouchillion knows what pulleys work properly together, hence the suggestion to TALK to them.
Re: Part # for 4 groove crank pulley [Re: Supercuda] #2314036
05/31/17 03:56 AM
05/31/17 03:56 AM
Clean out your inbox & I will make you an offer that you cant refuse.
