Bondo, will it hold up. #2313429
05/30/17 10:00 AM
05/30/17 10:00 AM
Austin, TX
lunacy Offline OP
lunacy  Offline OP
Austin, TX
I just picked up a 72 Dart. It has a pretty new paint job and looks like a great car. On close inspection both rear lower rear quarters, behind the back tires are pretty thick in bondo and there is evidence of some interesting body repair (sheet metal screws) looking from the backside of the quarter. Both corners by the rear window/trunk are heavily molded with filler as well. But, everything feels solid.
The car looks good, the paint is solid, no visible rust, and I'm in central Texas so that helps. I plan to use this car as a daily driver, 50 miles of highway driving a day, parking outside.
Will the body work hold up? Can I expect the car to stay looking decent for quite a few years or will these body repairs come back to haunt me pretty soon? I have no experience with heavily rust repaired vehicles.
Re: Bondo, will it hold up. [Re: lunacy] #2313433
05/30/17 10:13 AM
05/30/17 10:13 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
It's hard to make sweeping generalities about filler longevity vs. thickness. There are just too many variables. However, it has been my experience that if the panel flexes at all, thick filler will eventually fail. A prime example are the 'C' pillars. Eventually the filler will crack and fail. The body just flexes too much at this point. As to the quarters, what is pretty thick? I've seen 1/2" of filler on quarters that survived. You'll just have to see.
Re: Bondo, will it hold up. [Re: 6PakBee] #2313455
05/30/17 11:13 AM
05/30/17 11:13 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
flip of the coin.
Re: Bondo, will it hold up. [Re: bonefish] #2313474
05/30/17 11:46 AM
05/30/17 11:46 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
If it gets wet from the backside the filler can fail that way as well.
Re: Bondo, will it hold up. [Re: bonefish] #2313475
05/30/17 11:48 AM
05/30/17 11:48 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted By bonefish
flip of the coin.
iagree
Way too many variables and unknowns to say. beer
Re: Bondo, will it hold up. [Re: lunacy] #2313478
05/30/17 11:53 AM
05/30/17 11:53 AM
Austin, TX
lunacy Offline OP
lunacy  Offline OP
Austin, TX
A toss up, what I was afraid of. I have another Dart that is rust free and just a little bondo where the roof seam is, like they all have, but the paint job on it isn't as nice and its a little rougher interior wise so I'm trying to decide which one to keep.
The instant gratification that might fall apart or the one that's still a bit of a project.
Re: Bondo, will it hold up. [Re: lunacy] #2313481
05/30/17 11:58 AM
05/30/17 11:58 AM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Anytime filler is more than 3/8" thick you're asking for trouble. Based on your description I suspect the previous owner took the easy way out and just slapped on filler instead of replacing the metal, which would have been the correct way to repair those panels.
As others have said, flip a coin. However if it's really thick... it will fail sooner rather than later.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Bondo, will it hold up. [Re: lunacy] #2313492
05/30/17 12:15 PM
05/30/17 12:15 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Just drive it and don't worry about it. If it starts looking bad, take a couple of weekends and fix it the right way.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Bondo, will it hold up. [Re: lunacy] #2313496
05/30/17 12:24 PM
05/30/17 12:24 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Depends a lot on how the repair area was prepped and sealed. Done right with the right products, filler can last forever. Done poorly, as in cheap bondo slapped directly over rust or unsealed metal joints and you will see rust bubbling and rust juices pushing through in a year or two.
I've used sheet metal screws to hold my sheet metal in place while I do tack welds, but I always remove them and fill in the holes. If he left the sheet metal screws in place that tells me he didn't weld anything and piled the filler on heavy enough to hide the screw heads. These old cars flex a lot in that rear window/trunk area. I see a lot of mopars with cracking filler where guys tried to blend over the seam between the panel that goes in front of the trunk where it meets the quarter panel.
I think you should sell the car now while it still looks good. If you keep it, it'll look good for a year or two, then you'll start seeing some cracking around your trunk/quarter window area and some bubbling in your quarter panels behind and around the rear tires. 5 years from now you will be seriously unhappy with it.
Re: Bondo, will it hold up. [Re: lunacy] #2313524
05/30/17 01:02 PM
05/30/17 01:02 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
Being from NY and seeing and owning my share of bondo buckets my experience is, if you garage keep it and fair weather drive it you may be okay. If you keep the car in rain, it will bubble, crack and then start to fall out.
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Bondo, will it hold up. [Re: lunacy] #2313527
05/30/17 01:18 PM
05/30/17 01:18 PM
KY
65pacecar Offline
65pacecar  Offline
KY
If you are keeping one of them, I would keep the solid car and sell this one. Replacing a ratty interior is cheaper and easier than good body work, I would also be afraid of unseen stuff hiding in the bondo car.
Re: Bondo, will it hold up. [Re: 65pacecar] #2313541
05/30/17 01:45 PM
05/30/17 01:45 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Keep the solid car, sell the sheetmetal screwed one now while it still looks okay.
If it doesn't get wet it may last awhile but those screws are not a good thing. They are bound to start moving a bit with vibration and driving over bumps etc. over time. Plus you will always feel like you are driving a bondoed up junker.
Sheldon
Re: Bondo, will it hold up. [Re: lunacy] #2313554
05/30/17 02:03 PM
05/30/17 02:03 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
I'd be more inclined to keep the car with worse paint but more solid body panels...but based on other variables like suspension upgrades and the motor/trans/rearend it's still hard to say.
Re: Bondo, will it hold up. [Re: krautrock] #2313571
05/30/17 02:36 PM
05/30/17 02:36 PM
Austin, TX
lunacy Offline OP
lunacy  Offline OP
Austin, TX
I think I'm going to go with my gut and sell this pretty car with issues and keep the solid car. if it was going to sit in the garage and get driven on nice weekends I would probably do it differently, but I am truly looking for a daily driver and a paint job is cheaper than bad body work repair. I do have to say the guy was good with bondo, you can't see the screw heads on the front side anywhere. I will take some pics soon, I know it would have made this post a little better.
Thanks everyone for your opinions, my gut was already there, but sometimes the voice of a community makes you feel better about it.
Now lets see how good you are, which one is which.
Re: Bondo, will it hold up. [Re: lunacy] #2313599
05/30/17 03:20 PM
05/30/17 03:20 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By lunacy
...Now lets see how good you are, which one is which...
I'd say the black one is the Bondo queen.
Re: Bondo, will it hold up. [Re: lunacy] #2313606
05/30/17 03:32 PM
05/30/17 03:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If they didn't kill the rust behind the bondo the cancer will continue to grow and push that stuff off the car.
- Stu Harmon
Re: Bondo, will it hold up. [Re: 6PakBee] #2313613
05/30/17 03:41 PM
05/30/17 03:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I see a green and a blue one
Don't be the exception.
Re: Bondo, will it hold up. [Re: Supercuda] #2313627
05/30/17 04:10 PM
05/30/17 04:10 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
blue bondo bomb
Re: Bondo, will it hold up. [Re: bonefish] #2313676
05/30/17 05:32 PM
05/30/17 05:32 PM
Austin, TX
lunacy Offline OP
lunacy  Offline OP
Austin, TX
blue bondo bomb
winner winner. blue one is a lesson in bondo molding.
Green one really isn't bad, its just too dark of a green and it wasn't body worked so lots of waves down the sides and it wasn't jammed so the original medium green is inside everything and whoever painted it didn't get the underside of the body so if you lay under the car its primer with a bit of surface rust around the edges, but you can also see its all original metal too.
I know I'll just sell them both and see if i can find a new 2016 sitting on a lot still.
Re: Bondo, will it hold up. [Re: lunacy] #2313705
05/30/17 06:16 PM
05/30/17 06:16 PM
North Texas
O
oleman Offline
oleman  Offline
O
North Texas
I have a 440 powered 73 Dart 4 dr. Assembled in 1999. I removed all the body through-holes and bondoed the holes for a slick body look. I am not a body guy and did not get a smooth surface that really showed after I had it painted. Any rust I found (very little)I cleaned to shiny metal and also bondoed.
The body has not cracked or separated as of today. I am in North Texas the hot sun is the biggest paint and body killer around here. It mostly garaged and not a daily driver.
