727 Low Band Fails Again!
#2313373
05/30/17 01:51 AM
05/30/17 01:51 AM
Posts: 14 WA
359Inline6
WA
Hello everyone, new guy dealing with repeated reverse band failures. The trans is a 47RE, but lets ignore the OD and TC Lockup and stick to the main section of the trans, anyway here we go:
So I had the transmission rebuilt Fall of 2016. I had more money than time back then. Full Manual VB with LBA. No issues for 5,000 miles, then no reverse, no 1st gear engine braking, and no 3rd gear. This was the 1st failure. Nothing goofy inside but a fried rear band. Reverse servo was jammed hard in the activated (towards VB) position. This was an upgraded billet servo no less. It was stuck so hard (somewhat sideways) that I had to hit it with a hammer to get off the band apply arm.
Rebuilt the transmission myself. Drove around for 2 weeks, then bam no reverse in the driveway. Diagnosis? Yup Rear servo stuck and fried reverse band.
Rebuilt it again, this time used a whole different transmission case. I thought maybe the servo bore was out of whack causing the stuck servo (it looked fine though). Also replaced the billet rear servo with Sonax billet one that had more rounded edges. A couple more weeks pass, and bam. Here I sit with another reverse/low band failure.
This rebuild I will be replacing the VB. I am getting pretty good at trans R&R at this point but a little sick of this low band failing.
Any thoughts guys? Why the repeated failures with 2 different types of servos and 2 different cases even. This is a double wrap rear band BTW.
Re: 727 Low Band Fails Again!
[Re: 359Inline6]
#2313380
05/30/17 01:57 AM
05/30/17 01:57 AM
RapidRobert
Welcome here. sounds like a very interesting whodunit. Kunkel & the tranny guys will tighten you up.
[Re: 359Inline6]
#2313430
05/30/17 10:00 AM
05/30/17 10:00 AM
Posts: 20,652 in a cattle trailer down by th...
Guitar Jones
I'm thinking you have excessive pressure in that servo. I would put a gauge on it and see what it is. Also the adjustment could also be critical here. Too much travel of the servo and it has room to cock in the bore.
Is the servo solid or does it still have a spring on the rod to cushion the engagement?
[Re: 359Inline6]
#2313739
05/30/17 07:10 PM
05/30/17 07:10 PM
Posts: 25,910 Rio Linda, CA
John_Kunkel
Rio Linda, CA
For the adjustment, when building the trans I take it to 150 in/lbs, back out completely, then 150 again, then back out again, then 72 in/lbs and 2 turns out, That could be your problem, the 47RE calls for 3 turns out. http://dodgeram.org/tech/transmission/automatic/AT_band_adj.htm
[Re: 359Inline6]
#2313750
05/30/17 07:35 PM
05/30/17 07:35 PM
Posts: 14 WA
359Inline6
WA
Oops, yeah on the 1st attempt the front or rear clutch pack (I forget now which one it was) had a mild amount of wear on the clutches. Nothing extraordinary, no warped or blued steels, just faintly brown discolored red clutches. The rear band was gone and drum badly scored. The shop that rebuilt the trans said this was the first time they had ever done a Full Manual VB as well as trying to sell me a Dayco Converter for $1,100. So maybe they screwed something up, but it functioned just fine for 5,000 or so miles.
I also forgot that on rebuild 2 of 3 (my first rebuild after the shop's rebuild) I had the the transmission go into OD and Lock the TC. I have simple On/Off ground switches for both, and when slowing for traffic I noticed the truck trying to stall despite TCC switch being off. I could only get either OD or TC to go off by shifting into 2nd. Then upon return to 3rd, it would instantly go back into OD & Locked. The next day after the OD & TCC shenanigans, no reverse
On my 2nd rebuild (the one that just failed), I also started experiencing OD/TC nonsense. Sometimes it would go to 3rd then instant OD & TCC locked, sometimes 3rd then instant OD without TCC lock, sometimes no OD or TCC. I replaced both solenoids, and after a day or two it would go back to the same. It would even activate OD and Lock Up with the trans harness not connected. When I replaced the solenoids I made sure the lower valvebody valves of OD & TC were free moving.
As for the pressure test, I am getting 250-300psi (not fluctuating just best guess based on 200 psi gauge pegged) for reverse line pressure. The pressure goes to 0 when in Park. The servo is stuck again in the activated position.
Thank you so much for the help guys. I know it's hard to diagnose another's problems over the interweb.
[Re: 359Inline6]
#2313828
05/30/17 09:40 PM
05/30/17 09:40 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
I am at home and can't look it up, but your pressure sounds high. With excessively high pressure, the PR valve is jammed closed and the converter will not fill properly, which is release oil, which could be the cause of the TCC staying on and killing the engine, and maxing the governor pressure to cause it to go into 3rd quickly. I would double check the pressure issue first and also make sure that you are not cross leaking into the rear servo while driving hot. Keep your gauge on the rear servo, you should have zero pressure there unless in Man 1 or reverse.
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: zzyzxpat]
#2314189
05/31/17 03:02 PM
05/31/17 03:02 PM
John_Kunkel
Rio Linda, CA
The book says 260 psi in Reverse but it can go higher with cold fluid.
[Re: 359Inline6]
#2314631
06/01/17 03:37 PM
06/01/17 03:37 PM
John_Kunkel
Rio Linda, CA
I have seen cases that are deformed in the accumulator area that allow accumulator pressure to cross over and apply the rear servo but you state that you changed the case. The same could occur with the VB...check both the case and VB surfaces for flatness.
[Re: 359Inline6]
#2314789
06/01/17 08:40 PM
06/01/17 08:40 PM
Guitar Jones
Let's get all the info out at once ok?
The additional information you have now provided would have been nice to start with. When diagnosing anything you have to consider the big picture and take into account everything even if it seems unrelated.
So what vehicle is this in, what engine, stock PCM, wiring or how did you wire it, where did you ground it, did you use relays, whose valve body and whose converter and anything else that may seem to be off whether you think it's related or not.
