1971 and 1972 Two Speed B-Body Wiper Switch Wiring Diagrams #2313023
05/29/17 03:29 PM
05/29/17 03:29 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Online content OP
moparmike1  Online Content OP
Hi,
I'm trying to determine the difference in wiring between a 1971 B-body two speed wiper switch and a 1972 B-body two speed wiper switch. If anyone has the 1971 wiring diagram, could you please respond with a scan or picture?
I know the two speed switch is different between the two years, but need to know if the wiring to the bulkhead is the same. I don't know if the wiring from the bulkhead to the wiper is the same.
Thank you,
Mike.
Re: 1971 and 1972 Two Speed B-Body Wiper Switch Wiring Diagrams [Re: moparmike1] #2313031
05/29/17 03:40 PM
05/29/17 03:40 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Re: 1971 and 1972 Two Speed B-Body Wiper Switch Wiring Diagrams [Re: mikemee1331] #2313079
05/29/17 04:59 PM
05/29/17 04:59 PM
Originally Posted By mikemee1331
Thanks!
Re: 1971 and 1972 Two Speed B-Body Wiper Switch Wiring Diagrams [Re: moparmike1] #2313308
05/29/17 11:55 PM
05/29/17 11:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Wiring is the same, just the switch changes, due the diff switch between 71 and 72/74 so then the prongs and plugs disposition
Re: 1971 and 1972 Two Speed B-Body Wiper Switch Wiring Diagrams [Re: mikemee1331] #2313309
05/29/17 11:58 PM
05/29/17 11:58 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Those diagrams are wrong.
Will post differences in a few minutes
Re: 1971 and 1972 Two Speed B-Body Wiper Switch Wiring Diagrams [Re: moparmike1] #2313337
05/30/17 12:38 AM
05/30/17 12:38 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Here the differences, side by side
Left is 71, right is 72/74
Since 71 is blurry I overwritte the colors at a side of wire code
71s got two plugs, 72/74 got one piece larger plug.
switch can be indexed diff on diagrams but differences are noticeable
71 switch is also larger diameter than laters.
this section is the ONLY difference betyween 71 and 72/74. Bulkhead disposition is exactly the same, same as wiper harness.
applies the same to 3/var speeds.
Re: 1971 and 1972 Two Speed B-Body Wiper Switch Wiring Diagrams [Re: NachoRT74] #2313417
05/30/17 08:55 AM
05/30/17 08:55 AM
Thanks NachoRT74!
That's exactly what I am looking for.
Mike.
