Brake line help #2312757
05/29/17 02:34 AM
05/29/17 02:34 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I found that I have the wrong front brake line kit for my '69 Coronet.
I currently have what appears to be a power disk brake kit, but need a kit for manual drums. It looks like the proportioning valves are quite a bit different.
Anyhow, looking at SSTubes (Fine Lines), they have several kits numbers, but I don't know the difference between a "Type 5, 6 or 7" right front line?
Re: Brake line help [Re: 451Mopar] #2312760
05/29/17 02:42 AM
05/29/17 02:42 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Narrowing it down to type 5 or 6, but hard to see how each connects to the flexable brake lines
Re: Brake line help [Re: 451Mopar] #2312764
05/29/17 02:50 AM
05/29/17 02:50 AM
I'm thinking the hard line would be the std 3/16" double flare with the std 3/8-24 straight thread male tube nut slid on the line behind the double flare end (if that helps).
Re: Brake line help [Re: 451Mopar] #2312770
05/29/17 03:21 AM
05/29/17 03:21 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Must have been a long day today. I can just go look at my '69 Coronet 500, duh..
One of the things that upset me today is that I broke my brake flaring tool frown
Re: Brake line help [Re: 451Mopar] #2312871
05/29/17 11:30 AM
05/29/17 11:30 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Drum brakes don't have a proportioning valve, so yes everything is different. Who did you buy the kit from? If you got it from the Wrong Stuff, send it back, and go with Fine Lines.
Re: Brake line help [Re: 451Mopar] #2312927
05/29/17 12:57 PM
05/29/17 12:57 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I would suggest contacting the supplier on the tool and see if they will replace it beer
Re: Brake line help [Re: 451Mopar] #2312986
05/29/17 02:16 PM
05/29/17 02:16 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I think I got the lines from Inline Tube at the Mopar Nationals about 15 years ago. I must have asked for the wrong kit because all three '69 Coronets I have are/were drum brake cars.
The brake line tool is the K-Tool KTI-70081. I think the same tool is sold by Eastwood and Inline tube. It did a good job until I broke it. I guess I don't know my own strength. It only has a one year warranty, and I have had it for 3 or 4 years. There are a few ways I could try to fix it. I may mill the back flat where it broke and make a steel plate to replace the part that broke off?
