Re: Vavle spring compressor?
[Re: rt66jim]
#2312441
05/28/17 04:09 PM
05/28/17 04:09 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Jim I didn't find anything that looked good either. The ones Comp sells will not work, I had one to try from my 360 and no go.
My Dad has an LSM on car tool for his W9 heads. I used that LSM piece and made an adaptor from a piece of scrap aluminum so I could bolt it to the W2 heads. It worked like a charm, LSM certainly doesn't give their stuff away though.
68 Barracuda Formula S 340
[Re: rt66jim]
#2312939
05/29/17 01:14 PM
05/29/17 01:14 PM
Bad340fish
Tulsa OK
So you are saying they saw my adaptor on face book and copied me? lol
[Re: rt66jim]
#2313903
05/30/17 11:42 PM
05/30/17 11:42 PM
Bad340fish
Tulsa OK
That one appears to be the same one Comp and Pro Form Sell. It works great on stock heads but does not work well on the "Race" W2 rocker setup. I do not know if it will work with the Econo W2 setup though.
On the race W2 heads I was able to get the spring off with that tool but there was no way it was going back on. Perhaps a stock style spring but not something with 700lbs open. I had visions of pulling a valve spring out the sheetrock in my garage so I looked into other options.
