Help with shock setting on my car 71 Charger #2312003
05/27/17 02:19 PM
05/27/17 02:19 PM
Alberta
Wookie316 Offline OP
Alberta
71 Charger at Castrol
Looking for suggestions. More rebound in front shocks to get rid of 2nd hop?
RMS Alterkation front and street lynx in the back. 4.30 Dana 10.5x30 radial slick at 21 PSI
3000 RPM launch off brake
1.41 60 running 10.50's at 126ish
This pass the bottle was low so I was down a 1/10th
I will see if I can find where my shocks are set now.
Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Help with shock setting on my car 71 Charger [Re: Wookie316] #2312004
05/27/17 02:20 PM
05/27/17 02:20 PM
Alberta
Alberta
Shocks
Front
7 rebound
14 compression
Rear
10 RH 11 LH rebound
15 RH 13 LH compression
Re: Help with shock setting on my car 71 Charger [Re: Wookie316] #2312005
05/27/17 02:22 PM
05/27/17 02:22 PM
Alberta
Alberta
Also have a competition engineering anti roll bar installed.
Re: Help with shock setting on my car 71 Charger [Re: Wookie316] #2312261
05/28/17 05:17 AM
05/28/17 05:17 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Nice seeing another big car out there. Can't help on the suspension settings, I'm still running a near stock suspension.
Re: Help with shock setting on my car 71 Charger [Re: Wookie316] #2312415
05/28/17 02:57 PM
05/28/17 02:57 PM
Alberta
Alberta
Yeah, I get a lot of compliments in the pits. People are impressed what it does for the size it is
Re: Help with shock setting on my car 71 Charger [Re: Wookie316] #2312772
05/29/17 03:33 AM
05/29/17 03:33 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My '71 Charger was my street car that I put a stroker into, 4,150 pounds on the scale at Bandimere, but right now just running 11:80's @ 120 MPH (at Bandimere, usually way over 7,000 DA) with 1.7-1.8 60' when I get decent traction. I may have to get some cal-tracks, lighter T-Bars and adjustabe shocks to see if I can get it to hook up some day.
Re: Help with shock setting on my car 71 Charger [Re: Wookie316] #2312822
05/29/17 10:10 AM
05/29/17 10:10 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Front rebound is way too loose. Front end tops out, then it'll unload. The longer the front end can stay up the greater the load on the rear.
Doug
Re: Help with shock setting on my car 71 Charger [Re: Wookie316] #2312827
05/29/17 10:18 AM
05/29/17 10:18 AM
Alberta
Alberta
Right now I have my spare 440 in the car on spray as my 511 had a few issues so it sits right now. Car runs 11.40's with this 440 on motor. Add the spray and that puts me in the 10.50's. That is a 100 shot. Tried a 150 on Friday but the tires wouldn't hold off the line. I know it will take a little more off the line but I didn't have the right jet with me. So that will be next trip. Also this past trip I switched from ATF to John Deere Hy-Guard fluid in the trans because my top end MPH was low. I jumped from 123 and change to 126 and change. I'll take the 3 MPH gain. That little 8" body doesn't like the big Charger body.
Lenny from Ultimate had said that if he knew I was going to spray off the line he would of suggested leaving the 9.5" body he built for my 511 in. He thought when I was going to run the 440 it was going to be on motor alone. That was the plan until my buddy talked me into spraying it.
I may put the 9.5 body back in, but I'll have to muster up some ambition to do that. 😃
