Re: Lets talk AFR's for high speed cruise in a 496...
[Re: AndyF]
#2311384
05/26/17 05:38 AM
05/26/17 05:38 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Now THAT makes me feel better/more confident throwing timing at it. I've never used vac advance, and always set timing curves for idle timing, WOT, and get it in as fast as possible. Now, I need it for this type of racing.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#2311421
05/26/17 09:17 AM
05/26/17 09:17 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
13.5" Hg is a pretty good indicator the load is moderate. Consider the highest power valve is 10.5" and more often the engines don't need to go richer until less that. On a carb, that vacuum would also be helping p/t distribution, with the TBI I'm don't know. This is important to the extent that the tune has to accmodate the worst cylinder. This is one instance where to some extent two changes will have to be made together (timing and fuel). From RFS... You need to use a vacuum gauge with the A/F gauge when you road test and keep an eye on, compare, the A/F to the vacuum level as you crowd the throttle in part-throttle acceleration when the PV is not open. You want the A/F to be as lean as it will run well at a cruise and any mid-pedal acceleration when the vacuum is above the PV opening point. As you crowd the throttle harder the engine will tolerate leaner A/F, and that may be as lean as 16.5 or even 17.5 on some engines which have good or better than average vaporization and A/F distribution characteristics. Use as lean a main jet as will accelerate at part-throttle without balking. In fact, the part-throttle torque and response usually improves with the leaner A/F up to the balking point.
Understand that the leaner it is, the more unburned Oxygen there is in the exhaust residual, so the successive combustion cycles have the advantage of hot Oxygen from previous cycles. It should come as no surprise that hot Oxygen improves combustion more than Carbon Monoxide. Also, leaner than 14.7/1 (stoichiometric) the temperatures drop off faster and more than an equal percentage on the rich side. In other words, from 15/1, 17/1 is cooler than 13/1, however the lean A/F burns slower and so needs more timing, AKA vacuum advance. The highest temperatures occur near and slightly rich of 14.7/1. from Steady cruise AFR and pressure at WOT posted by Tuner bottom of page 2.
[Re: 67Charger]
#2311556
05/26/17 01:55 PM
05/26/17 01:55 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
With my TBI, I am running 15:1 AFR at cruise at ~45 degrees of timing at 50kPa. I could lean it out 16:1, but coolant temp would start to creep up gradually.
I crank with 20 degrees, have 30 at idle, 32 at WOT, and 45 at cruise
For Ref...cal table from Holley for 650HP 496"
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: BigBlockMopar]
#2311577
05/26/17 02:10 PM
05/26/17 02:10 PM
67Charger
Erda, UT
You are hardly adding any 'vacuum' advance at all in your table. I'm seeing just 0 to 2 degrees of vacuum advance.
Did you enter the initial and max. mechanical advance numbers based on your engine's dynosheet? Do you have a copy of that to post here?
I presume the 609HP was made with a known timing advance curve and rpm. That advance number could/should safely be put in the corresponding 100% kPa load field.
The porting afterwards would vary the numbers but a dynosheet should still provide a good lead to modify your ignition map in TunerStudio. Here's the dyno sheet. The timing was setup to maintain 18° idle (crisp, clean) and max power at WOT using pump gas. Timing was all in by 2200. The dyno sheet here is a test run on C-12 the picked up about 10 HP with 34° total instead of the 30° that pump 91 liked. NOte the BSFC's from 3700 to 4700. This thing was built with mid-range efficiency in mind. This was also using a 3.5" PV.
[Re: 67Charger]
#2311588
05/26/17 02:25 PM
05/26/17 02:25 PM
Posts: 865 lancaster,california
johnnycuda
Hey Dan, need to change your profile pic for the new look '67
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: OUTLAWD]
#2311589
05/26/17 02:27 PM
05/26/17 02:27 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
For Ref...cal table from Holley for 650HP 496" Who's "reference table" is that? Looks pretty stoneage to me. Good luck starting an engine with 31° advance without idle/starting compensation.
[Re: 67Charger]
#2311620
05/26/17 03:38 PM
05/26/17 03:38 PM
BigBlockMopar
The Netherlands
Did you go from 36° to 30° advance in one go, without checking in between advance numbers? Efficient head chambers, amongst other things, can make an engine need less advance. But 30° still feels kinda low. I would think 32-34 would be more inline with expectations. What heads are on the engine anyway? I agree that putting the car on the dyno (again) and having a plan on what to achieve is better/quicker than trying to come up with a good map by trial and error. But ofcourse, the dyno-operator needs to be on par with your goal, and not just go for the most power @ WOT. In short, I think the dyno-session would be done by holding the engine at 4500rpm and have the dyno provide a load so the engineload is at 55 kPa. Then vary timing advance in the corresponding cell(s) and play with the fuel-table, to see if you can lower the engine load. A knock-sensor would be a great help and pretty much a necessity when doing this. Looking again at your ignition table, I would first make sure all the RPM-ranges in your table step up equally (Re-Map). Now every column goes up either by 200, 300 or even 600 rpm. As for the 18° advance at idle; I always like to put the transmission in Drive and then check how much advance the engine wants when idling. On my current/daily engine it's 24° @ 550rpm where the engine load is the least. It idles with 20-21" vacuum.
[Re: BigBlockMopar]
#2311634
05/26/17 04:11 PM
05/26/17 04:11 PM
OUTLAWD
Metro Detroit
For Ref...cal table from Holley for 650HP 496" Who's "reference table" is that? Looks pretty stoneage to me. Good luck starting an engine with 31° advance without idle/starting compensation. One of the pre-loaded Holley cals for a 496" BBC
[Re: 67Charger]
#2318653
06/09/17 08:19 PM
06/09/17 08:19 PM
67Charger
Erda, UT
I actually got in contact with Rich through FBBO and the short version, per his advice, is I went to 25° at idle and continued fiddling with it until I found peak vacuum and a good AFR. I've now got it at 29° at 1000 rpm, sitting at 64 kPa (11"Hg vacuum) and 13.7 AFR. The 700 RPM column is set at 32° to help stabilize the idle. Cranks at 15°. That's 10 kPa better than it was before. I'll see how it does tomorrow on another cold start.
I also moved everything at 45 kPa and lower to 40°, and tapered back to my 30° as it approaches the mid 80's kPa. I revved the engine in neutral to 2500 and toggled back and forth from 30° to 40°. The audible difference was significant. That flat, muffled tone disappeared with the increase in timing. I'll have to keep working on the table, but there is DEFINITELY a lot in there to be improved. I'll get a screenshot of the current version tomorrow after I get home.
Drive-testing will have to wait until I figure out the fuel leak off the top of the tank when it is full...
[Re: 67Charger]
#2318739
06/09/17 10:55 PM
06/09/17 10:55 PM
67Charger
Erda, UT
So.... Port EFI time.
I bought the tools for my CNC to drill out rails and machine the manifod and bungs for my Mopar M1 single plane. Knowing what my intended usage is, here's what I'm looking at:
-EV6 injectors, probably in the 45 - 50 lb range ---bungs as high and flat (tops leaned inward towards the centerline of the engine) as possible, or right in the flange aimed at the valve? -Keep the FAST throttle body on there for now since it has all my sensors built in, just not use the injectors -Batch fire the injectors (MS2 won't support sequential) ---What is the typical batch configuration Even/Odd, 1458/2367, etc?
[Re: 67Charger]
#2318754
06/09/17 11:48 PM
06/09/17 11:48 PM
Posts: 2,913 Pattison Texas
CSK
Pattison Texas
I have just used bank fire, if not doing sequential.
