1972 B b body coolant recovery tank + bracketry #2307336
05/19/17 01:08 PM
05/19/17 01:08 PM
S.E. Michigan
ZIPPY Online content OP
ZIPPY  Online Content OP
S.E. Michigan
Is it true this part is still not reproduced?
Can't find a reasonably close-appearing one anywhere with the weird bracket on the bottom and so on.
Rich H.
Esse Quam Videri
Re: 1972 B b body coolant recovery tank + bracketry [Re: ZIPPY] #2307341
05/19/17 01:23 PM
05/19/17 01:23 PM
Ct, Hartford
birdfan70 Offline
birdfan70  Offline
Ct, Hartford
The tanks can be found used or NOS and Jimmy Boros has the two brackets in cast aluminum if he has any left.
Re: 1972 B b body coolant recovery tank + bracketry [Re: birdfan70] #2307367
05/19/17 02:33 PM
05/19/17 02:33 PM
None
71rm23 Offline
71rm23  Offline
None
To the OP, no "correct" ones and agree with birdfan's statement
Re: 1972 B b body coolant recovery tank + bracketry [Re: ZIPPY] #2307398
05/19/17 03:45 PM
05/19/17 03:45 PM
S.E. Michigan
S.E. Michigan
Thanks. Have a complete original setup I saved from a long time ago, and no car for it to go on. Almost threw it out a couple times over the years, glad I didn't. Somebody probably needs it.
Rich H.
Esse Quam Videri
Re: 1972 B b body coolant recovery tank + bracketry [Re: ZIPPY] #2307445
05/19/17 05:13 PM
05/19/17 05:13 PM
None
71rm23 Offline
71rm23  Offline
None
Someone on here might/should be able to duplicate that bracketry because seems like that is the hardest part to come by.
Re: 1972 B b body coolant recovery tank + bracketry [Re: ZIPPY] #2309797
05/23/17 02:35 PM
05/23/17 02:35 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I know someone who needs it! No shipping required. grin
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 1972 B b body coolant recovery tank + bracketry [Re: DynoDave] #2310479
05/24/17 05:56 PM
05/24/17 05:56 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
