Re: My project just got really complicated
[Re: 1fastrunner]
#230924
02/21/09 12:31 AM
02/21/09 12:31 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I am guessing the car was hit on that side?
Looks like alot of piece work welding there.
Not good.
[Re: NTOLERANCE]
#230925
02/21/09 10:18 AM
02/21/09 10:18 AM
Posts: 2,346 west palm beach, florida
modelmakerinc
It looks to me like the rear k-frame mounting area of the rail is crushed up (in). Pieces/patches were then welded in.
In my opinion sparks around the engine are the least of your troubles.
If the k-frame is the same one which was hit then it may be bent(twisted) as well. you may need to look into another one.
If the damage is from rust and that was someone soulution then tha k-frame is probably ok.
You may want to look into getting a complete or partial frame rail for that side. the rail can then be spliced into the good part of the existing Rail.
[Re: 1fastrunner]
#230930
02/21/09 03:12 PM
02/21/09 03:12 PM
Posts: 340 Ohio
tak
Ohio
Here's where the front passenger frame appears to have been repaired.
In this photo and the one above it it appears the bottom of the repair seems to have a very square edge to it. to me it looks like a piece of angle iron has been welded, this is the area between the cross member bolts. Anybody else see this. Just seems to square at the bottom, your can see it in the picture above right beside the cross member. As long as the frame to the firewall side of the crossmember seems strait, it should be a easy fix.
[Re: 1fastrunner]
#230931
02/21/09 05:39 PM
02/21/09 05:39 PM
yeah,what 4Bbodies said-get on a level surface and take some measurements-plumbob frame points to floor,mark same[chalk]and measure every which way-stretching a string will also let you know if you have a serious frame problem-or pay a body shop that you trust.use a dremel with a cut off wheel and hang wet/damp rags around your spark area to grind those welds-work slow and steady so the wheels [you'll need 9 or 12/ 3 to a pack]won't bust ![](/ubbthreads/images/graemlins/thumbs.gif)
#230932
02/21/09 08:27 PM
02/21/09 08:27 PM
Posts: 2,126 Hunt Valley, Maryland
1fastrunner
Well, I know the car was hit at some point in the '70's, it also has a different door and the jamb has had some work done to it. The K frame is shot anyway, I'm getting it replaced. As far as the frame rail goes, are they available, or do I need to get one from another car? I wasn't sure I could replace that section, if I could, that would be my choice to get it back to as normal as possible. If you missed my earlier post about the K frame, here's another photo of it's condition. The more I find out about this car, the list of "issues" is already a mile long, I'm surprised I've been safe in it so far. Jim
