Re: Tire Inner Tube Question
[Re: parksr5]
#2308160
05/20/17 09:17 PM
05/20/17 09:17 PM
Posts: 43,161 Bend,OR USA
Cab_Burge
Check with M/T ,Hoosier and Coker to see if they have any you can use I think I may have a decent set of used ones if you can't find any new ones you like, what is the maximum outside diameter of the stems you can use ?
[Re: parksr5]
#2308227
05/20/17 11:25 PM
05/20/17 11:25 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Were the pull through valve stems tubes racing tubes? I have seen guy's use implement tubes , they have pull through stems. There not the same as racing tubes but will work for the large street tires.
[Re: parksr5]
#2308280
05/21/17 12:54 AM
05/21/17 12:54 AM
rowin4
I would never use tubes that I didn't know how old they were. Racing tubes are not cheap being close to $100. each . Trying to save a few bucks could cost you a lot more. On the subject of drilling your new rims. The nut that retains the metal valve stem will cause more damage than the drill bit. Another thing to keep in mind when putting tubes in slicks. The tubes have to be able to move, if you don't use a lot of tire talc the tube will stick to the tire rip. Also, If you put tubes in slicks that have previously were soaped to prevent leakage , all the soap residue needs to be rinsed out completely and dried or the tube will stick to the tire and rip even with tire talc.. Unlike a tubeless tire your tire will go flat within a minute when the tube rips..
[Re: parksr5]
#2308301
05/21/17 01:37 AM
05/21/17 01:37 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I just drilled mine out when I ran into this. My wheels aren't chrome, but I think if you tape them first, you'd be fine. Rubber valvestems arent NHRA legal at some performance point I believe. Something to be aware of.
