Pro stock block question #230774
02/20/09 08:38 PM
02/20/09 08:38 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Just out of curiosity, do NHRA Pro stock motors use steel or aluminum blocks? Can they run either and what is teh maximum bore and bore spacing allowed?
I thought they used aluminum, but was then told they use steel. Can they run any bore and stroke combo as long as they stay at or below 500"? No real reason other than I am just curious to know.
Re: Pro stock block question [Re: Scamp451] #230775
02/20/09 08:54 PM
02/20/09 08:54 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
They use cast blocks,but once opon a time the "Wayne County" team used KB blocks when Dodge made its comeback in 1990!the BS. of a pro stock in the NHRA is 4.9"
Re: Pro stock block question [Re: boatracer572] #230776
02/20/09 09:03 PM
02/20/09 09:03 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Aha! I was right in one respect. I knew I read that Aldermans Wayne County B1 motor in the '87 Daytona was an aluminum block.
Post deleted by Defbob [Re: Scamp451] #230777
02/20/09 09:07 PM
02/20/09 09:07 PM
Re: Pro stock block question #230778
02/20/09 09:21 PM
02/20/09 09:21 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
The blocks that NHRA ruled against were actual GM blocks.They were cast for them by Caterpillar.Mopar at the time was assigning Mopar P/N's to GM parts in order to make things "legal".I have pictures of Nickens "Mopar" engine in the back of a Dodge truck on a dolly and ones in the Avengers,and they are without any doubt GM engines.
The original version of the B-1 engine(1987-88) may have been Keith Black,but were cast.The later blocks were RJ and C&S made blocks.
Nautilus Racing-
Re: Pro stock block question [Re: Chris2581] #230779
02/20/09 10:02 PM
02/20/09 10:02 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
I heard the same about the "CAT" blocks. A guy down around these parts had one of Geoffrions old motors, and you really had to do a double take because it had a Mopar logo or Pentastar or something like that on it, can't remember which.
Wasn't there a blunder about the heads too around '98, '99? The ones they ran before they brought the Hemis in had the exhaust ports spaced like a Chevy or Hemi head, they didn't have the 3/5 and 4/5 paired together lfike a wedge head. I noticed that on Alderman's motor in the pits at Maple grove around that time frame.
Re: Pro stock block question [Re: Scamp451] #230780
02/20/09 10:26 PM
02/20/09 10:26 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
is the pheonix block a chevy style block?
Re: Pro stock block question [Re: Defbob] #230781
02/20/09 10:29 PM
02/20/09 10:29 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The Phoenix blocks had splayed caps like a Chevy block, who they were cast by I have no idea. I do recall the Eicke engine basically being a Chevy engine with Mopar Part numbers.
At that kind of level of power, alot of the engines would end up being very similar anyway.
AL....
Alan Jones
Re: Pro stock block question [Re: LA360] #230782
02/20/09 10:33 PM
02/20/09 10:33 PM
Arizona
Chris'sBarracuda Offline
Arizona
I think Merlin cast those..
Koffel would know everything about those things..
Chris..
Re: Pro stock block question [Re: Scamp451] #230783
02/20/09 10:58 PM
02/20/09 10:58 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
The blocks were by Cat.
The heads were actually Pontiac castings with MOPAR numbers on them. This had been the case since about 1996 when Eicke took over the MOPAR banner from Wayne County.
Allen raised cain with NHRA over the new HEMI when it first came out. At that time, only Nickens and Morgan could get HEMI parts from Chrysler. Allen wanted to be allowed to run the older configuration while they sorted out the new HEMI and NHRA said no to his request.
The truth be told, AJ got quite a few parts from Morgan while they were ramping up their HEMI program.
Re: Pro stock block question [Re: 74DusterP457] #230784
02/20/09 11:32 PM
02/20/09 11:32 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Mopar actually pulled the approval from the Cat/Eicke motors and left Allen and Roy swinging in the breeze. IIRC, Allen won a race and kinda made Nickens look bad.
Re: Pro stock block question [Re: slantzilla] #230785
02/21/09 12:03 AM
02/21/09 12:03 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Yeah and the Mopar/Eicke head at the time was the latest generation of the spread Pontiac head with Mopar stamped on it.
8.30's @3400 lbs
Re: Pro stock block question [Re: Mike Swann] #230786
02/21/09 12:16 AM
02/21/09 12:16 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Actually pro stock blocks are made from CGI *Compacted graphite iron*
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Pro stock block question [Re: bigtimeauto] #230787
02/21/09 12:58 AM
02/21/09 12:58 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
They called the Eicke motors Podge for a reason. They did'nt start using CGI in the Hemi until the 9 cam bearing blocks came out. The early motors had problems with the main webs cracking. There are 3-5 different versions of heads and blocks out there. The one I have is a second gen,skirted style, 4.678 bore with a 9.085 deck. I have seen pistons as large as 4.740. Don't leave a lot of material between the cylinders.
Bob
Re: Pro stock block question [Re: Scamp451] #230788
02/21/09 02:29 AM
02/21/09 02:29 AM
AndyF Offline
AndyF  Offline
When the starter is on the passenger side and there isn't any distributor hole up front you start to think it might not be a Mopar block.
Re: Pro stock block question [Re: AndyF] #230789
02/21/09 02:40 AM
02/21/09 02:40 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just for grins and giggles here is a current Pro Stock block, along with some other stuff. Thought they were cool..BTW note the cam journal size against the main bearing size
Cams for comparisons sake. Current PS in the foreground, typical roller in middle and a 55mm in the rear.
How about a crank shot
New design 99 Hemi valve cover
Re: Pro stock block question [Re: Al_Alguire] #230790
02/21/09 08:36 AM
02/21/09 08:36 AM
back home in georgia ,lake sid...
105630 Offline
105630  Offline
I don't know about that valve cover,is it so ugly,are they moroso's Al.
Re: Pro stock block question [Re: slantzilla] #230791
02/21/09 09:31 AM
02/21/09 09:31 AM
Rowlett, TX
mopar addict
mopar addict
Rowlett, TX
That is exactly what happened. There was some politics being played behind the scenes at that time and AJ got the short end of the stick.
I recall reading an interview with David Nickens during that time frame and he wasn't real happy with their performance and he was feeling quite a bit of pressure from MOPAR. His words were "It sucks to be me right now".
Re: Pro stock block question [Re: AndyF] #230792
02/21/09 09:47 AM
02/21/09 09:47 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
those are the T/S heads right?
Re: Pro stock block question [Re: 74DusterP457] #230793
02/21/09 09:52 AM
02/21/09 09:52 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I bet those fabbed valve covers seal better than the POS mag ones! Al, is that the latest gen Hemi block? I had heard they did away with the skirted style but never seen one. Looks like they are up to 70mm cams now.
Bob
