1970 road runner horn keeps beeping #2307133
05/19/17 12:21 AM
05/19/17 12:21 AM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi,i have an original 1970 road runner convertible. I took the steering wheel off the other day .when I put it back on after I tightened steering wheel nut the horn keeps beeping. if I loosen steering wheel nut a little and pull wheel forward it stops beeping.any suggestions as to what to look for.thanks
Re: 1970 road runner horn keeps beeping [Re: barryv] #2307135
05/19/17 12:25 AM
05/19/17 12:25 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
You pinched the wire. Take the wheel back off. Make sure the wire can't touch any metal in there. When you press the horn ring/button it gives the 12V ground and triggers the horn.
Re: 1970 road runner horn keeps beeping [Re: Dave Hall] #2307639
05/19/17 10:16 PM
05/19/17 10:16 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
i will check wire,thanks
