Page 1 of 3 1 2 3
906 TEMPLATE #2307104
05/18/17 11:45 PM
05/18/17 11:45 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Did Chrysler make any BB 906 porting templates? If so, anyone have access to them? Thanks
Re: 906 TEMPLATE [Re: A/MP] #2307112
05/18/17 11:49 PM
05/18/17 11:49 PM
I have some xeroxed 1-1 on a sheet of paper. you can glue em to something stiff to use as templates. PM me your address & if I can find em I will send you a copy next week (pretty sure I know where they are at).
Re: 906 TEMPLATE [Re: A/MP] #2307113
05/18/17 11:50 PM
05/18/17 11:50 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Dear Lord.
Wasn't that like, 1978?
Luckily, Mopar guys never throw anything away...somebody still has those little plastic cut-out templates laying around.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 906 TEMPLATE [Re: MoparBilly] #2307119
05/18/17 11:59 PM
05/18/17 11:59 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I still have two sets of the original plastic ones. Lol
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 906 TEMPLATE [Re: A/MP] #2307189
05/19/17 02:53 AM
05/19/17 02:53 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have some of the plastic ones 😁
Re: 906 TEMPLATE [Re: FastmOp] #2307190
05/19/17 03:00 AM
05/19/17 03:00 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Still got a set over my Dad's place, right next the Direction Connection Engine and Chassis manuals. up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: 906 TEMPLATE [Re: MadMopars] #2307191
05/19/17 03:08 AM
05/19/17 03:08 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Here's a link to a PDF with some templates I came across awhile back. Figured I'd pass it along. -Trent up
Mopar head porting templates
Re: 906 TEMPLATE [Re: A/MP] #2307283
05/19/17 12:08 PM
05/19/17 12:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The only problem is....... They instruct you not to do what's required if you're really trying to see some nice gains.........which is rework the short turn.
I've lost count of the number of bowl blended, ported, big valve bowl blended, big valve ported 906/915 heads that I've had on the flow bench over the last 25 years that didnt break 240cfm......... All because the short turn was left untouched.
It's a double edged sword......... Don't rework the short turn......they don't flow much.
Rework the short turn incorrectly....... They don't flow much.
This is why for the novice or first time porter, the 346/902/452 head is a much better choice.
Ther basically is no short side radius to screw up.
Just blend away the sharp edge, along with the rest of the normal bowl blending..... And you have a decent head.
I could probably rough bowl blend a 346 head in less time than it would take to cut out the templates.
Come to think of if, I had someone send me some stage v heads with big valves that were done using the stage v specific templates...... Mid-240's iirc.
Re: 906 TEMPLATE [Re: MoparBilly] #2307324
05/19/17 12:58 PM
05/19/17 12:58 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Originally Posted By MoparBilly
Dear Lord.
They're on the shelf, next to the .654 mushroom tappet cam.
You never know when you might need something like that, right (?)
"Tonight, on this episode of 'Hoarders':"
Rich H.
Esse Quam Videri
Re: 906 TEMPLATE [Re: fast68plymouth] #2307349
05/19/17 01:52 PM
05/19/17 01:52 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Re: 906 TEMPLATE [Re: A/MP] #2307363
05/19/17 02:31 PM
05/19/17 02:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
This is like Goldy Locks.......
A - First set - fresh valve job, OE type valve, bowl blended, no short turn work
B - Second set - dyno time only, valve job, Manley valve, bowl blended, short turn work done not as well as It should be
C - Third set - fresh valve job, Ferrea valve, bowl blended, pinch smoothed over, short turn done juuuust right.
All with 2.08 valve:
Lift-------A-----B-----C
.100---62.4/ 69.0/ 68.4
.200--118.3/148.8/138.4
.300--172.1/203.7/204.9
.400--224.9/238.1/251.3
.450--223.0/226.8/263.4
.500--224.9/228.7/260.8
.550--230.5/224.9/257.0
.600--232.4/224.9/251.3
Re: 906 TEMPLATE [Re: A/MP] #2307383
05/19/17 03:08 PM
05/19/17 03:08 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I suppose 500" with a 590/600 lift cam and 915s that makes 645 hp 620 tq is like the seven dworfs?
Have a great day
Iowan
"obsolete is neat"
Re: 906 TEMPLATE [Re: Iowan] #2307389
05/19/17 03:16 PM
05/19/17 03:16 PM
PA.
"Little"John
"Little"John
PA.
Who in the heck would mess with those lousy 906 heads. Oh that's right, we did and had to 28 years ago. LOL. Those good for nothing super stock springs too.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 906 TEMPLATE [Re: A/MP] #2307453
05/19/17 05:17 PM
05/19/17 05:17 PM
So. Burlington, Vt.
So. Burlington, Vt.
Couple more for ya.....
Real nice 906 "F" head(not all F heads are great, but the best untouched 906's I've tested have been F heads), never touched previously.....
A- as removed from engine, oem valve and valve job
B- same port as above, grind 3 angle seat, back cut OE valve, minor bowl blend, no work to short turn
Lift------A/B
.100---63.0/68.4
.200--122.0/142.0
.300--179.3/201.3
.400--216.2/230.7
.450--223.0/234.4
.500--226.8/233.7
.550--232.4/230.0
.600--238.1/224.4
C- 915 head, old style MP 2.14 valve with back cut, bowl blend, basically no short turn work, and someone did a little opening/smoothing at the pushrod pinch;
Lift------C
.100---71.0
.200--145.1
.300--195.6
.400--229.4
.450--238.1
.500--238.8
.550--238.1
.600--237.0
Re: 906 TEMPLATE [Re: A/MP] #2307461
05/19/17 05:29 PM
05/19/17 05:29 PM
So. Burlington, Vt.
So. Burlington, Vt.
A 915 someone sent in for tweaking......
A- what looked like a half hearted attempt at a bowl blend, OE valve, so-so valve job, no back cut
B- same port, remachine valve seat, bowl cut, blend bowl and short turn, Manley valve with back cut
Lift-------A/B
.100---61.2/69.0
.200--128.1/142.0
.300--187.8/206.1
.400--224.9/249.4
.450--225.6/260.8
.500--228.6/266.4
.550--232.4/268.3
.600--234.6/268.3
Re: 906 TEMPLATE [Re: A/MP] #2307468
05/19/17 05:37 PM
05/19/17 05:37 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
I still have a set of templates in one of my tool boxes. Hell I still have a set of 906 heads that are ported on the shelf.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: 906 TEMPLATE [Re: A/MP] #2307481
05/19/17 05:54 PM
05/19/17 05:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
Last one.....
A- "Ported" 906 head, SI brand 2.14 valve, no back cut, valve job done with a radius for bottom angle. Pinch opened to 1.070, guide boss trimmed a bit, some short turn work.
Didn't look too bad, and actually didnt work that bad in the upper mid-lift compared to a lot of what I see of these things.
B- open bowl more, relieve chamber adjacent to valve, longer top angle on valve job, a little more work on the guide boss, lay back the short turn, back cut valve...... Same cylinder as above
Lift-------A/B
.100---70.4/71.6
.200--124.4/156.6
.300--180.5/217.1
.400--229.4/255.1
.450--241.9/257.7
.500--243.8/258.9
.550--248.3/259.7
.600--248.3/258.9
.650--234.3/258.9
.700--234.3/259.7
The newer heads???
902 head(1974):
A- OE valve with back cut, grind 3 angle seat, less than 10 minute blend
B- open bowl a little more, bullet nose guide boss, pinch to 1.025", Manley valve with back cut
Lift--------A/B
.100---67.2/ 70.4
.200--139.0/142.0
.300--202.5/205.4
.400--230.5/244.5
.450--237.0/249.4
.500--240.7/254.0
.550--243.8/257.0
.600--245.7/253.2
Re: 906 TEMPLATE [Re: pittsburghracer] #2307487
05/19/17 06:03 PM
05/19/17 06:03 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I haven't figured out if it's stubborn or cheep, maybe I just wanted to prove the old junk can work.
Have a great day
Iowan
"obsolete is neat"
Re: 906 TEMPLATE [Re: MoparBilly] #2307516
05/19/17 06:46 PM
05/19/17 06:46 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Dear Lord.
Baaaaaahahahaha, I did until about a year ago! Found them in a drawer. Hey, back in the 80's, they helped me get my 440 smogger motor duster into the 11's.
Re: 906 TEMPLATE [Re: Iowan] #2307545
05/19/17 07:42 PM
05/19/17 07:42 PM
PA.
"Little"John
"Little"John
PA.
Just keep having fun. That's what it's all about. When the fun stops, quit.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Page 1 of 3 1 2 3
