1972 B b body coolant recovery tank + bracketry
#2307336
05/19/17 01:08 PM
05/19/17 01:08 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Is it true this part is still not reproduced?
Can't find a reasonably close-appearing one anywhere with the weird bracket on the bottom and so on.
Rich H.
Esse Quam Videri
Re: 1972 B b body coolant recovery tank + bracketry
[Re: birdfan70]
#2307367
05/19/17 02:33 PM
05/19/17 02:33 PM
Posts: 2,592 None
71rm23
None
The tanks can be found used or NOS and Jimmy Boros has the two brackets in cast aluminum if he has any left. To the OP, no "correct" ones and agree with birdfan's statement
[Re: ZIPPY]
#2307398
05/19/17 03:45 PM
05/19/17 03:45 PM
ZIPPY
S.E. Michigan
Thanks. Have a complete original setup I saved from a long time ago, and no car for it to go on. Almost threw it out a couple times over the years, glad I didn't. Somebody probably needs it.
Rich H.
Esse Quam Videri
