frozen spark plug #2304884
05/15/17 02:27 PM
05/15/17 02:27 PM
michigan
rscottick Offline OP
michigan
Any good way to remove a plug thats frozen solid into a cast head?
Re: frozen spark plug [Re: rscottick] #2304902
05/15/17 02:48 PM
05/15/17 02:48 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Soak it with PPBlaster and apply heat.
Re: frozen spark plug [Re: rscottick] #2304911
05/15/17 03:04 PM
05/15/17 03:04 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
If you can get an impact wrench on it, use it with proper socket,,,impact version if available and fits, recommended. Six point nevertheless for certain recommended. Should pop right out. Are they iron heads or aluminum. Use anti seize on replacement plugs
Re: frozen spark plug [Re: Sxrxrnr] #2305162
05/15/17 09:39 PM
05/15/17 09:39 PM
What Stump said, & I would oil it every day for several days then get after it. You NEED it to come out in one piece.
Re: frozen spark plug [Re: rscottick] #2305436
05/16/17 12:04 PM
05/16/17 12:04 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Warm the cylinder head with two large electric soldering irons like plumbers use,
and chill the lower metal section of the spark plug with either a chunk dry ice,
or the drug store Wart removal spray chillers.
Make metal temperature differences your assistant.
I once saw in the 1970s an older field representative from the Roots Blower company use metal BB's during a bearing installation. He used both hot and cold BB's . He chilled his BB's with cold blow off gas from a high pressure cylinder of CO2 gas.
Re: frozen spark plug [Re: 360view] #2305469
05/16/17 01:26 PM
05/16/17 01:26 PM
Warm the cylinder head with two large electric soldering irons like plumbers use, and chill the lower metal section of the spark plug with either a chunk dry ice, or the drug store Wart removal spray chillers. Make metal temperature differences your assistant.
Ding ding ding We (may) have a winna.
Re: frozen spark plug [Re: rscottick] #2305480
05/16/17 01:54 PM
05/16/17 01:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Way to much work.Saok it with a good penetrating oil. PB is like pea to me I used castle at work and now use the WD40 penetrant.Then work it back and forth easy.use a spark plug socket.at worki must have remover a few hundred that werefrozen.I used the ratchet to get them moving the used my 3/8 impact on real low to work them back and forth till they came out.Even with aluminum heads and had plugs that wer in for decades on some they came out and no damage.On my old ram charger snow plow truck the plugs were so bad that even a Snapon plug socket would not get them out.The crumbled.I finally got a metric socket on and worked them out.No damage.Rocky
Chrysler Firepower
Re: frozen spark plug [Re: rscottick] #2305551
05/16/17 04:22 PM
05/16/17 04:22 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
You didn't mention what engine, I just spent 7 hours on a spark plug challenge on my 01 Ram with 5.9 Magnum.
without too many gory details, got the shield off, with a dremel and carbide burr , then the hex was rounded, used a tool from Grip tite, that promptly snapped off the all the spark plug except the threads that remained in the engine.
Started the engine and the ceramic blew out and I got an easy out to remove the threaded portion..
Yes,
I soaked it for 3 days in PB and Kroil... no help.
Still have 2 more to do...
Re: frozen spark plug [Re: sthemi] #2305667
05/16/17 08:28 PM
05/16/17 08:28 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Ouch!
Re: frozen spark plug [Re: 360view] #2305787
05/16/17 11:36 PM
05/16/17 11:36 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Never mind.
Re: frozen spark plug [Re: rscottick] #2306532
05/18/17 05:52 AM
05/18/17 05:52 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
got the pics of my frozen spark plug mess.
Nasty heat shields...made a real mess...
Thought I was gonna have to pull the head...
finally got it out. 7 hrs. One spark plug.
Re: frozen spark plug [Re: sthemi] #2306540
05/18/17 07:48 AM
05/18/17 07:48 AM
E
elmor353 Offline
elmor353  Offline
E
From the looks of things you may have to pull the head anyway, if it's something that you are going to run. I'm sure that there must be pieces of porcelain and junk in the cylinder.
Re: frozen spark plug [Re: elmor353] #2306543
05/18/17 07:56 AM
05/18/17 07:56 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
May be able to vacuum any residue from cylinder with special vacuum attachment. Might check with a borescope from Costco or HF.
Re: frozen spark plug [Re: rscottick] #2306550
05/18/17 08:31 AM
05/18/17 08:31 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Boy am I glad I moved away from the rust belt in 1985. If I had a car like that out here I'd call the scrapper because there is no way I'd even care to mess with it.
Don't be the exception.
Re: frozen spark plug [Re: rscottick] #2306683
05/18/17 01:19 PM
05/18/17 01:19 PM
USA
3
360view Offline
360view  Offline
3
USA
I noticed some NGK brand ignition wires from a 4 Cylinder a few weeks ago and saw that these had bright metal heat shields attached to the silicone rubber plug boots. In my opinion that is a better design alternative than pressing the heat shields into a fit in the heads.
Was it really worth it on the Magnum V8s to use a lower quality insulation for the boots around the plug ceramic and then try to extend its working life by deflecting infra-red radiation with the pressed in metal heat shields?
I kinda suspect this was due to the 100,000 mile emissions warranty.
Re: frozen spark plug [Re: Supercuda] #2307211
05/19/17 05:48 AM
05/19/17 05:48 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Yeah, the highlight of my year is buying some rust free sheetmetal from AZ or TX...
A couple of the guys in Wisconsin make monthly runs to keep our old trucks on the road.
