Page 4 of 5 1 2 3 4 5
Re: how accurate is Hughes cfm charts? [Re: justinp61] #2305190
05/15/17 10:30 PM
05/15/17 10:30 PM
western PA
I
Ironmike Offline
Ironmike  Offline
I
western PA
Originally Posted By justinp61
Originally Posted By fast68plymouth
Originally Posted By krautrock
BPE, it sounds to me like you've gone above and beyond what is the usual good customer service. up
100% !!!
X3!
I don't know many businesses that would what Rod has done.
He went above and beyond. I knew he was solid the first time I talked to him. I have stated that fact many times.
If more businessmen had the ethics and values that Rod has, things would be a lot better all around.
Personally, I would rather have them found the issue, grind on another pair and just send them to me. I even told Rod I'm more than happy to be their "test mule". I have a solid bottom end just sitting here, and a dyno 20 minutes away. I really wanted to "stay in the loop". I STILL feel that way.
I could be wrong, but I have a gut feeling that big egos get in the way. And it ain't mine or Rod's. Couple posts here made me feel like someone was talking down to me.
Like I said, I could be wrong. Won't be the first time.
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2305212
05/15/17 10:56 PM
05/15/17 10:56 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Did you ask Dave for a refund on his heads?
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2305311
05/16/17 01:53 AM
05/16/17 01:53 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I have a lot of respect for Mr. Bloomer bringing these to market. Even more respect for the way this situation was handled.
Was there any flow data published on these after the release? Forgive me if there is, but I haven't seen any.
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2306492
05/18/17 02:39 AM
05/18/17 02:39 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I see alot of hp on the table with a few dyno proven pieces i had on my stock block eddy headed Barton moTor.
9hp Wilson spacer
13hp vacuum pump
And beleive it it made 11hp more on 93 octane fuel then the sunoco race gas.
This was on a 502hp 418 Motor Barton built motor
Re: how accurate is Hughes cfm charts? [Re: fishy340] #2306503
05/18/17 02:59 AM
05/18/17 02:59 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
I will post longer video but internet fighting tonight.
https://youtu.be/6Edxg_vihrA
It's late.
Will try to update what we did on flow bench.
Sorry I had numbers the night I got the heads just forgot to save file and the was first night I had time to put them back on.
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2306620
05/18/17 12:09 PM
05/18/17 12:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Just over 300cfm at a tad under 28".
301.6 @ 27.68" corrects to 305.1 @ 28.00"
Nice numbers.
Re: how accurate is Hughes cfm charts? [Re: fast68plymouth] #2306711
05/18/17 01:46 PM
05/18/17 01:46 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Nice numbers.
Actually the numbers are corrected to 28"👍🏻
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2306723
05/18/17 02:06 PM
05/18/17 02:06 PM
New Smyrna Beach FL
scottb Online content
scottb  Online Content
New Smyrna Beach FL
Looks nice great work as always Brett by the looks of the numbers there is more going on with this motor then whats being posted it looks like those heads have great numbers
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2306725
05/18/17 02:07 PM
05/18/17 02:07 PM
New Smyrna Beach FL
New Smyrna Beach FL
Re: how accurate is Hughes cfm charts? [Re: W5DART66] #2306813
05/18/17 03:54 PM
05/18/17 03:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
Nice numbers.
"CCFM"........ Didn't catch that.
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2306953
05/18/17 07:44 PM
05/18/17 07:44 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Well that flow bench right there was within 2cfm of the flow bench Jeremy and ten speed used for butch Kemps sb2 motor.
The same motor that Dynoed in the area of 1050hp and by the time it was put on a dyno in MI a day later it picked up 50hp.
It might truly be the engine builder here or something he's missing....
Blaming head flow #s against someone that's makes 800 hp sbs like changeing his underwear is Balsy especially when The TOP engine builders praise his work.
Uratchko or BES would've seen this problem without bolting them on i would imagine.
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2307978
05/20/17 03:15 PM
05/20/17 03:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
Never I good idea to compare data from different dynos...... But.....
416, 12:1, port matched SV, old school 850 Holley, we have a couple sets of dyno headers for these things, and to the best of my recollection I used the 1 7/8 x 3.5 on this motor.
Flat tappet cam, old school .842 lobes, 265/270-106 in at 102, .375/.375, crane 1.5 ductile rockers, straight c12 gas, timing 36, lash .022/.022.
RPM heads with some mid-level effort porting, around 270cfm.
539 uncorrected hp.
Baro 29.98, .53 vapor pressure, 78deg air temp.
BSFC in the low/mid- 4's until the last 4 lines, where it went up to .48-.49.
2.02 valve, 4.00 bore:
Lift-----flow
.100---65.4
.200--132.9
.300--190.3
.400--234.3
.500--268.3
.550--277.8
.600--269.1
.650--268.3
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2308265
05/21/17 12:33 AM
05/21/17 12:33 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i'm the one that posted on the FABO thread asking about low torque number with similar combos with a SV manifold.
maybe the SV manifold combined with the cylinder pressure going the wrong way with the BPE heads were two of the reasons he didn't hit closer to his expected numbers right from the start.
would've been nice to see cranking psi numbers...
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2308296
05/21/17 01:30 AM
05/21/17 01:30 AM
So. Burlington, Vt.
So. Burlington, Vt.
I just figured I'd post the numbers to show the missing 100ft/lbs at 4000rpm isn't because it can't be done with the SV.
Using small-ish heads and a 4" stroke, things should be well underway by 4000-4200rpm.
With that other motor, it looked pretty soft down low with both sets of heads by the looks of the sheets.
Re: how accurate is Hughes cfm charts? [Re: fast68plymouth] #2308317
05/21/17 02:33 AM
05/21/17 02:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Too me they both had bad valve jobs to be
that weak down low.... JMO
wave
Re: how accurate is Hughes cfm charts? [Re: MR_P_BODY] #2308356
05/21/17 08:26 AM
05/21/17 08:26 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
From what is posted, I think the engine underperformed due to a combination of the engine builder/designer. Many of the people commenting here would have simply listened to the goals of the original poster and executed a package that would perform to his expectations using most of the same parts. There are risks you take as a home builder/hobbiest (for the money you may save? the satisfaction of doing it yourself? etc?) that may result in disappointing results unfortunately. But as we see the heads from Rod and Brett are not the reason for this engine not performing to expectations. I too feel Rod has reacted beyond fair and it does not surprise me because he has a legacy of that character. I still feel this post is worthwhile, it serves for all a learning experience on many fronts.
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2308416
05/21/17 12:08 PM
05/21/17 12:08 PM
So. Burlington, Vt.
So. Burlington, Vt.
That other motor would have certainly made for an interesting "science experiment".
Swap out a component at a time until you find what's holding it back.
Was there really one thing that was a major contributor, or was it really just a few things that each played a part in the less than expected/desired results?
I will say this, from my perspective....... I don't see anything glaringly wrong with it "on paper", and would have also been looking for better results myself.
This is slightly off topic, but this thread made me think of it again......
I'm really surprised no head company, even someone like Pro Comp has offered up a new aluminum W2 head.
All the support products already exist..... Intakes, rockers, headers.
Just cast the long valve W2's in aluminum. Use 11/32 bronze guides, come up with a more modern closed chamber........ I would think they would sell pretty well.
They're a known quantity........ They work.
Anyway....... That's just a thought from a BB guy.
Re: how accurate is Hughes cfm charts? [Re: fast68plymouth] #2308522
05/21/17 02:30 PM
05/21/17 02:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wish they would also.. I would be buying a set today
to get the iron ones off.. I sure wouldnt mind a 40#
weight loss
wave
Re: how accurate is Hughes cfm charts? [Re: fast68plymouth] #2308583
05/21/17 04:38 PM
05/21/17 04:38 PM
Washington
madscientist Offline
Washington
The problem is most guys never wanted to buy the valve train and cried about what it costs. Those guys think they can make power with a stock rocker. Will never happen.
Re: how accurate is Hughes cfm charts? [Re: 79410aspenrt] #2308620
05/21/17 06:07 PM
05/21/17 06:07 PM
New Smyrna Beach FL
New Smyrna Beach FL
Batten did make a W2 aluminum heads witch I now think we're the start of the Indy heads
