Re: Leaf Spring Weight Distribution ??
[Re: Dart451]
#2305669
05/16/17 08:30 PM
05/16/17 08:30 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Tighten lt front torsion bar to raise rt rear weight. it wont take much to adjust the weight difference you have so it should not make the car sit too high on lt side. If not you have to shift battery to rt side.
JAKES AUTOMOTIVE
[Re: Dart451]
#2305672
05/16/17 08:34 PM
05/16/17 08:34 PM
JAKE68
Shelby mi.
The difference in your weights from side to side most likely not make a difference in 60"s. What shocks do you have, what springs do you have, what front shocks what front torsion bars. How much powe do yo make what converter. Those are all the things that would have a bigger impact on 60's.
JAKES AUTOMOTIVE
[Re: Dart451]
#2305798
05/16/17 11:54 PM
05/16/17 11:54 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I would look at getting all the weight I could get on the right rear tires by moving the battery, fuel cell over and so on I added another group 27 battery in my old pump gas (3450 lbs. with me in it) 1971 Duster to help it run faster, especially at the track. It was NHRA legal to 10.00 and I ended up getting kick off at Woodburn 1/4 track for running 9.99 ET through the complete 3.0 inch exhaust system with the air cleaner on My motor started off as a 511 C.I. 400 block stroker motor with 906 iron heads, 9.25 to 1 compression ratio and a low deck six pack set up, it ended up being 4.375 bore with a 4.300 stroke crank (517 C.I.) and a set of M.W. port size Indy SR heads(10.78 to 1 comp. ratio) with a matching 4500 Indy 400-3 intake and a 1050 CFM Holley Dominator carb. It was a ladder bar car with coil overs from day one though, I never drove that car with leaf springs
[Re: Dart451]
#2305800
05/16/17 11:58 PM
05/16/17 11:58 PM
Posts: 667 IL
Dart451
IL
We scaled the Road Runner tonight. Ended up two full turns up on driver side and down two turns on passenger side, 6 cylinder torsion bars, SS springs in rear. Ride height stayed about the same and driver side is slightly higher then passenger side, almost even with driver in the car. Ended up with 40 more pounds on RR with driver in the seat. Driver under 150 pounds. hopefully weather lets him test friday night.
Will mess with Dart tomorrow night see what I end up with. Thought of changing to ladder bar for a winter project.
[Re: Dart451]
#2306110
05/17/17 02:49 PM
05/17/17 02:49 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I played w/this on my Dart and one thing for sure, 2 batteries on the pass rear hooked and booked way better that a single and proven at the track. That's about 40 lbs. w/a gel battery and my car is biased more on the dr side and went a 1.33 60 last time out footin to 2500. We played around quite a bit raising the ft. w/a floor jack and watching the rear scale #'s and it's crazy how much they change at launch so if it leaves good and goes straight,they are what they are............
