Page 3 of 3 1 2 3
Re: 470 ci project underway!! Crank install [Re: 383man] #2295004
04/27/17 01:51 PM
04/27/17 01:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thankxxx.............. thumbs
Re: 470 ci project underway!! Piston install [Re: Thumperdart] #2304861
05/15/17 01:55 PM
05/15/17 01:55 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Rods and pistons installed without any clearance drama up Very happy with the Molnar rods beer
Re: 470 ci project underway!! Piston install [Re: ccdave] #2304871
05/15/17 02:10 PM
05/15/17 02:10 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
More pics
Re: 470 ci project underway!! Piston install [Re: ccdave] #2304874
05/15/17 02:11 PM
05/15/17 02:11 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Sorry for the double pics. Moparts does not like my I pad....
Re: 470 ci project underway!! Piston install [Re: ccdave] #2304879
05/15/17 02:20 PM
05/15/17 02:20 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
The girdle install on this engine took a little twist in that I decided to drill a hole in the girdle directly center between the studs on caps 1,2,3 and 4. Why not take advantage of the threaded 3/8's hole in the center of the aluminum caps and fasten the caps to the girdle. Introducing the worlds first 3 bolt main boogie
The Highly Contrivesial GIrdle!!!!
Re: 470 ci project underway!! Piston install [Re: ccdave] #2304895
05/15/17 02:37 PM
05/15/17 02:37 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Nice!Ever wonder about the shim variance?I used a 3/8 girdle on my iron caps.
Re: 470 ci project underway!! Piston install [Re: ccdave] #2304896
05/15/17 02:37 PM
05/15/17 02:37 PM
How tight did you torque that center main cap bolt to?
Is it enough to lift and distort the main caps work scope
Probably not a good idea to do that work twocents
Re: 470 ci project underway!! Piston install [Re: Cab_Burge] #2304900
05/15/17 02:44 PM
05/15/17 02:44 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Don't you worry Cab pity all shimmed up and tighted up to 25 ft pounds with a little locktight 👍 This idea was discussed with the owner of SDC who makes the caps along with ASE, NASA, the late Dick Landy and Kieth Richards from The Rolling Stones 👍
Re: 470 ci project underway!! Piston install [Re: ccdave] #2304917
05/15/17 03:15 PM
05/15/17 03:15 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Pistons
Pistons
Re: 470 ci project underway!! Piston install [Re: ccdave] #2304920
05/15/17 03:17 PM
05/15/17 03:17 PM
an8sec70cuda Offline
Lookin' good! Love all the pics and descriptions in this thread.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 470 ci project underway!! Piston install [Re: ccdave] #2304995
05/15/17 05:38 PM
05/15/17 05:38 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
Cab, our caps (bcrproducts) tend to be pretty tall in the middle of the cap. this allows for minor shimming and then interfacing with a girdle. if you're going to go this route we really recommend the girdle caps as more load is transferred to the girdle and away from the studs.
a lot of other after market aluminum caps are very similar to stock style caps and even if you use a longer stud on the girdle you're not gaining anything in terms of clamping.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 470 ci project underway!! Pistons and girdle install [Re: ccdave] #2305027
05/15/17 06:23 PM
05/15/17 06:23 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
popcorn
Re: 470 ci project underway!! Pistons and girdle install [Re: StealthWedge67] #2305308
05/16/17 01:50 AM
05/16/17 01:50 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Stay tuned!!!!!! Windage tray / oil pan install next!!!!!
Next will be the windage tray/ oil pan install !!!!!!!! Stay tuned as the new Edelbrock Gen 3 Victor heads will be in very soon!!!!!!!!!!!!!!!!
Re: 470 ci project underway!! Pistons and girdle install [Re: ccdave] #2305562
05/16/17 04:37 PM
05/16/17 04:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Hey Dave love the pictures, love the build. Do yourself a favor and set both heads on the dowl-pins to make sure that they don't bottom out on the heads. They appear to be setting pretty high in the pictures. I cracked a set of very nice 906 heads many years ago by not checking this after the heads and block were surfaced at the machine shop. Well worth the 30 seconds it takes to check it with a feeler gauge.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 470 ci project underway!! Pistons and girdle install [Re: ccdave] #2305587
05/16/17 05:46 PM
05/16/17 05:46 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Thanks for the tip!
Re: 470 ci project underway!! Pistons and girdle install [Re: ccdave] #2305644
05/16/17 07:43 PM
05/16/17 07:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep, I always install em w/no gasket and see how they fit and the same w/metering blocks on carbs...........
Page 3 of 3 1 2 3
