Issues with Precision shifter rear pull bracket 47rh #2303313
05/12/17 01:00 PM
05/12/17 01:00 PM
Dirty Dena, Maryland
dodge turbo Offline OP
Well we are using a 47rh in a diesel project and the bracket blocks the rear fluid port
We've called PPP several times with no solution. Seeing if any of you guys have had similar issues or solutions.
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303363
05/12/17 02:48 PM
05/12/17 02:48 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
How about plugging it off and drill and tap a hole from the top of that boss
JAKES AUTOMOTIVE
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303385
05/12/17 03:27 PM
05/12/17 03:27 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Looks like it could be the wrong bracket?
I would think it would need to run parallel down the pan rail
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303390
05/12/17 03:37 PM
05/12/17 03:37 PM
Guitar Jones Offline
Is that for the throttle pressure or the shifter? If it's for the shifter something isn't right, it doesn't even line up with the lever.
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303394
05/12/17 03:44 PM
05/12/17 03:44 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
They should change their name to PPPP (P*ss Poor Prior Planning)
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303407
05/12/17 04:07 PM
05/12/17 04:07 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
how about a 90* fitting but that may take a line fitting adjustment to do it.
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303411
05/12/17 04:12 PM
05/12/17 04:12 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
J-body had to fab his own bracket for a 727 too. There is a thread on here somewhere with pictures.
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303413
05/12/17 04:17 PM
05/12/17 04:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run the 518 with the B&M shifter.. what is the distance
from the trans ear to the bottom of that bracket hole.. looks
like you can add a few washers to lower that bracket..
I had to add 2 or 3 washers to clear the lip of the pan..
as said already the shifter should be level so if its
level you should have some distance to lower that bracket
and you might need to trim the to of that bracket down
so you just clear that trans ear
wave
Re: Issues with Precision shifter rear pull bracket 47rh [Re: MR_P_BODY] #2303429
05/12/17 05:11 PM
05/12/17 05:11 PM
Its right against the hole for the fitting.
Im not plugging and tapping the case im not a hill billy
Just trying to see if anyone else is have this issue with the rear pull shifters
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303474
05/12/17 06:43 PM
05/12/17 06:43 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
HILL BILLY?????? Guess you don't know how to reengineer your way around. Or spell.
JAKES AUTOMOTIVE
Re: Issues with Precision shifter rear pull bracket 47rh [Re: JAKE68] #2303484
05/12/17 06:57 PM
05/12/17 06:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree with Jake... the easiest way to get
around this issue is to drill and tap the top
of the boss and plug the current hole... that
way your cable would line up
wave
Re: Issues with Precision shifter rear pull bracket 47rh [Re: JAKE68] #2303576
05/12/17 10:05 PM
05/12/17 10:05 PM
Im very well educated for one so dont get butt hurt that i dont want to be a hack.. And two im not re-engineering a transmission port, thats plain dumb when i can just build another bracket.
I made a post to see if this is a common theme with the precision shifters or not.
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303598
05/12/17 10:53 PM
05/12/17 10:53 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Sounds like it's more dumb to have to-reengineer a hole bracket and make everything line up when doing the hole could have been done in a short time. I was only trying to make your life easier But since you have all the brains then why did you have to even put up this post. Seams like you try and help someone and they blast you and call you dumb. I'm out of here........
JAKES AUTOMOTIVE
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303599
05/12/17 11:01 PM
05/12/17 11:01 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
I used my old b&m bracket and lever with my PPP shifter on my 904. Is yours rear exit I'm assuming?
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303696
05/13/17 02:38 AM
05/13/17 02:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303698
05/13/17 02:50 AM
05/13/17 02:50 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I had made my original prototype from aluminum. I gave it to a customer of mine who is a master welder (restores BSA motorcycles... a true artist). He whipped this one up for me out of steel. I then used my Dremel so that it would fit snug to the contour of the trans ear. tighten it up and it does not move. I sent these picts to PPP hoping they would follow through and start offering something similar. Apparently it wasn't a good idea smile
Works great and was icing on the cake for a dang nice shifter.
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303699
05/13/17 02:55 AM
05/13/17 02:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and I should have read the WHOLE thread. This bracket I did will have you in the same position you are presently in. I'd have to look at my 47re case and see if something like Jake mentioned would work. You're swimming in uncharted waters I'm thinking. Time to get creative! I do know that part of the case is pretty sensitive. Many a trans has been cracked there from simply over tightening line fittings.
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303703
05/13/17 03:15 AM
05/13/17 03:15 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
well my 47 case is a bit different... but still very delicate in that area. I don't think you'll get away with plugging and re-drilling out of the flat area above the hole.... unless you can weld it and drill and tap at more of a straight out angle. You might try a bracket like mine, but shorter. The cable would come in at an angle to the shift arm, but it might not affect the operation... something to think about.
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303721
05/13/17 07:31 AM
05/13/17 07:31 AM
On top of that the 47 uses a half inch cooler line instead of the 727s five sixteenths. I would make another bracket and possibly use some steel braided hose with a 45 degree fitting or something like that.
Good luck with your truck, what valve body are using?
Re: Issues with Precision shifter rear pull bracket 47rh [Re: dodge turbo] #2303737
05/13/17 09:39 AM
05/13/17 09:39 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Might try looking on some marine web sites and see if anyone makes a morse cable with a shorter distance on end that you'd use at the trans. That way you could have the cable mount closer to the shift lever ahead of that fluid port... or even a longer one to put it below/behind the fluid port.
