55mm cam bearings #2302082
05/09/17 11:13 PM
05/09/17 11:13 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
I'm looking at a block that has 55mm roller cam bearings. How special are these cams? Is there anything I need to know about installation, base circle, use? How easy is it to get cams? Where would I look for some good used 55mm cams?
[image][/image]
Re: 55mm cam bearings [Re: sgcuda] #2302096
05/09/17 11:34 PM
05/09/17 11:34 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Seems like they are $7-800 from Comp Cams, but they don't always have the 55mm cores in stock.
Re: 55mm cam bearings [Re: Forest] #2302175
05/10/17 02:24 AM
05/10/17 02:24 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
We keep a couple blank cores on the shelf to grind into hemi or wedge as we need them. Hard to get.
Todd
Re: 55mm cam bearings [Re: sasquatch] #2302233
05/10/17 08:33 AM
05/10/17 08:33 AM
sgcuda Offline OP
sgcuda  Offline OP
Todd
Is there something I should do to the block to put in a better/more popular style cam bearing?
[image][/image]
Re: 55mm cam bearings [Re: sgcuda] #2302305
05/10/17 11:42 AM
05/10/17 11:42 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Not much to do at this point. It is kinda like unboring a hole. Todd
Re: 55mm cam bearings [Re: sgcuda] #2302367
05/10/17 01:48 PM
05/10/17 01:48 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
the 55 millimeter stuff is becoming more and more popular... what's nice about having the 55 roller cam tunnel... you can also run a 60mm Babbitt in the same hole.. I have been running mine for some time with great results... I would not be afraid of it one bit
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 55mm cam bearings [Re: WHITEDART] #2302493
05/10/17 05:28 PM
05/10/17 05:28 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I AGREE with White Dart. I prefer the flat bearing. Just my opinion and the bearings are not priced bad at all. Todd
Re: 55mm cam bearings [Re: sgcuda] #2302585
05/10/17 09:42 PM
05/10/17 09:42 PM
sgcuda Offline OP
sgcuda  Offline OP
I'm guessing that the bigger bearings allow for a larger diameter lobe and keep a decent size base on the shaft. Doesn't bother me, 55 or 60, as long as I can get a cam that will work well with my combo.
[image][/image]
Re: 55mm cam bearings [Re: sgcuda] #2302613
05/10/17 11:08 PM
05/10/17 11:08 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
They use the same core. 55mm roller and 60mm flat. You need something pretty nasty to use one but they for sure work. Todd
Re: 55mm cam bearings [Re: sgcuda] #2302625
05/10/17 11:30 PM
05/10/17 11:30 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I'm a vote for the 55mm roller bearing now. They won't turn in the cam tunnel and blow your investment up. Also, try turning a motor with a wrench with a 55mm babbit bearing and then turn one over with a roller bearing. There's no comparison.
Re: 55mm cam bearings [Re: sgcuda] #2302848
05/11/17 02:18 PM
05/11/17 02:18 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I'm guessing this is a SB Mopar R3 block. Ford seems to have good prices on the roller cam bearings. I bought a SS Hemi block that was bored to Ø2.500" which seemed like a strange size. It turns out that is a Ford bearing size for a Ø2.125" journal size. That is just over Ø54mm. Here is the Ø55mm roller bearings.
http://www.jegs.com/i/Ford-Performance/397/M-6261-D351/10002/-1
The Ø2.125" journal seems to be popular for the Hemi roller cams. These are the bearings I bought for my block. My engine builder likes the roller bearings as more oil is available for the main bearings.
http://www.jegs.com/i/Ford-Performance/397/M-6261-A460/10002/-1
Floyd Lippencott IV
Re: 55mm cam bearings [Re: mr_340] #2302896
05/11/17 04:11 PM
05/11/17 04:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
BB..........
Re: 55mm cam bearings [Re: sgcuda] #2302991
05/11/17 07:42 PM
05/11/17 07:42 PM
sgcuda Offline OP
sgcuda  Offline OP
Indy Max RB
[image][/image]
Re: 55mm cam bearings [Re: sgcuda] #2303042
05/11/17 09:44 PM
05/11/17 09:44 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Might make sure the rear bearing can got to 55 Roller on that block...Seems like the way the oiling works there isn't enough room to bore the cam tunnel that big on the back.
Re: 55mm cam bearings [Re: Forest] #2303293
05/12/17 12:15 PM
05/12/17 12:15 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
My KB Alum 426 has 54mm, #1-4 & #5 standard
Re: 55mm cam bearings [Re: Forest] #2303308
05/12/17 12:52 PM
05/12/17 12:52 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I have an Indy block,KB, and older mega block with all 5 cam bearings 55mm roller,the oiling is not a problem
Re: 55mm cam bearings [Re: sgcuda] #2303334
05/12/17 01:48 PM
05/12/17 01:48 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
My Hemi block has the standard rear (#5) cam bearing. The Ø2.125" roller bearings in 1-4.
Floyd Lippencott IV
Re: 55mm cam bearings [Re: sgcuda] #2303381
05/12/17 03:18 PM
05/12/17 03:18 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I have built several Indy Maxx and Mopar(World Products) blocks with all 5 and no issues to report. I have not seen a block like you have Mr 340. Interesting. Is it a World block or an earlier Mopar block?
Re: 55mm cam bearings [Re: sgcuda] #2303396
05/12/17 03:51 PM
05/12/17 03:51 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I'm sure it started out with standard cam bearings. I bought the block from Dan Zrust, he got it from Jim DeFrank. Supposedly Joe Allread machined it many years ago. The decks have been cut down to 10.400", big cam bores, bored to Ø4.310". Waiting on heads from Bob at Modern Cylinder Head and a big pile of cash to fall from the sky to move the project forward. It's one of the older MP Hemi blocks, Cummins style.
Floyd Lippencott IV
Re: 55mm cam bearings [Re: mr_340] #2303405
05/12/17 04:03 PM
05/12/17 04:03 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
2.125 is a 54mm bearing. or 2.1259
