Page 1 of 3 1 2 3
Clogged pick-up or oil pump failing? #2303034
05/11/17 09:35 PM
05/11/17 09:35 PM
Tacoma, Washington USA
Adam71Charger Offline OP
I'm working on and LA 318. It has an after-market oil pressure gauge. I was driving home and thought I heard a quiet tapping sound around 3000 RPM. After about 30 seconds I could tell it was a tapping sound and I looked at my oil pressure gauge and it was bottomed out at zero. Immediately shut the truck off and coasted to a stop. Went and check my oil which was just fine and full. I went to restart the truck and no oil pressure again so I shut it off. I waited a couple minutes and tried again and the oil pressure went right up to 35 as normal. I drove the truck home with perfect oil pressure and then parked and took off valve covers and there was no signs of sludge whatsoever or blocked drain holes.
Since then the oil pressure will drop randomly and I'll turn the truck off immediately and roll my steering wheel around side to side then turn the truck back on and the oil pressure goes right back up to normal again. Is this the sign of a pickup tube getting clogged up with gunk in the pan or the oil pump failing?
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303052
05/11/17 09:56 PM
05/11/17 09:56 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
I'd probably try a new gauge first.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303071
05/11/17 10:18 PM
05/11/17 10:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Lifters clacking support no oil pressure, doubt it's the gauge.
Doesn't really matter if it's a clogged pick up or the oil pump. Your gonna have to drop the pan.
If it's is a clogged pick, question is what clogged it? Hopefully it's not the nylon teeth of a silent timing chain setup. You mention it's a truck (no real details there BTW) dunno if trucks got that setup or not, but who knows what someone might have put in there.
Don't be the exception.
Re: Clogged pick-up or oil pump failing? [Re: Supercuda] #2303076
05/11/17 10:24 PM
05/11/17 10:24 PM
amxautox Offline
amxautox  Offline
He said 'quiet tap', lifter rattle isn't quiet. And how old is the gauge?
Tom
author unknown
Re: Clogged pick-up or oil pump failing? [Re: amxautox] #2303077
05/11/17 10:25 PM
05/11/17 10:25 PM
with the tapping coinciding with the zero gauge reading (if I am reading that right), it definitely has an actual psi issue. I'd replace the filter (no fram) first & if no relief (you might get lucky) but I'm thinking the screen is plugged & unfortunately you know what that means (pull pan).
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303106
05/11/17 11:22 PM
05/11/17 11:22 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Depending on the truck, some have easy to remove pans. Sure sounds like clogged screen.
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303123
05/11/17 11:46 PM
05/11/17 11:46 PM
Sorry Supercuda I was hands free speak-to-text'ing this thread over my phone while driving and was paying more attention to the road.
Its a 1980 d100 with a 318, manual transmission. Just bought it a couple weeks ago. It was nice enough, had some nice parts in it, and it was dirt cheap, no issues at time of purchase.
It has a 2 barrel intake, a small holley 2 barrel carb (havent even looked at size), MSD 6A, cheap headers, full single exhaust with muffler, low pressure aftermarket out of tank fuel pump. The PO said the engine use to have aluminum heads and a big cam, but that cam got flattened and destroyed so he removed the heads and cam and put the stock iron heads back on and a new cam slightly bigger than stock. He also said the cylinders looked good as well. He changed the oil and filter but didnt remove the pan. I didnt nit pick and grill him for more detailed info, as he was selling me the truck for $700 and it had over $1000 in ignition, carb, headers and exhaust. Even if the engine didnt run it still wouldve been a good deal.
It has a jacked up throttle cable but other than that it has not given me any issues. The oil pressure problem started earlier today. Although it will drop randomly, I noticed it will do it if I come to a hard stop. Sometimes when I stop I'll just watch it gradually drop to about 10lbs, then slowly to zero. Thats what made me think there's crud in the pan and its getting sucked up and clogging the pickup tube, and when I shut the engine off and shake the truck, it disturbs the clog and things go back to normal until it clogs again. It could be debris from the destroyed camshaft as well (if that even happened).
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303125
05/11/17 11:48 PM
05/11/17 11:48 PM
The pressure gauge is the type with a tube that has oil in it from the engine. I can watch it go dry when the gauge goes to zero.
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303138
05/12/17 12:15 AM
05/12/17 12:15 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Could be a few things, IE: Junk oil filter, or sticking bypass valve on the pump itself.
I would suggest a new pump, oil and filter if you're trying to "SAVE"
it.
Keep rolling the dice and you'll get all of those with a replacement motor, twocents beer popcorn
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303143
05/12/17 12:20 AM
05/12/17 12:20 AM
TJP, it just started happening today, Im going to drop the pan tomorrow and take care of business. The motor runs really well and theres no point in sacrificing it. What I meant in the earlier post was that the price was so cheap I didnt grill the dude about specifics, and the truck is worth more with no engine at all than the price he sold it for. Doesnt mean I dont care about this engine, it would be a waste to be reckless with it and lose it
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303182
05/12/17 01:28 AM
05/12/17 01:28 AM
Illinois
SIX225 Offline
SIX225  Offline
Illinois
My Durango would occasionally read zero at idle. Didn't think much of it as I didn't hear any ticking, etc. It's got a lot of miles on in, and I don't change the oil like I should. Assumed it was just the sender. At some point I finally changed the oil on it and a few months latter, I realize the gauge hasn't acted up in a while. Guessing I had a bad filter. That was probably a year or two ago, and now I've got 300K on it. For what it's worth, I think it was a Puraltor filter on it.
Re: Clogged pick-up or oil pump failing? [Re: SIX225] #2303207
05/12/17 02:51 AM
05/12/17 02:51 AM
This oil gauge is not faulty. When the gauge gets down to zero I literally can watch the motor oil disappear from the small diameter clear tube that brings it to the gauge. And after about 30-60 seconds the engine starts making a tapping sound that changes with engine speed. So Im going to be very surprised if I don't find a bunch of crap in the pan and/or on the face of the pickup tube
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303238
05/12/17 08:38 AM
05/12/17 08:38 AM
Illinois
SIX225 Offline
SIX225  Offline
Illinois
I was saying that I thought I had a bad sender, only to find out it WAS the oil filter like others suggested.
Re: Clogged pick-up or oil pump failing? [Re: SIX225] #2303244
05/12/17 09:45 AM
05/12/17 09:45 AM
Ok, that would be nice if that was my problem, then just an oil and filter change would be necessary. What did your filter look like when you removed it?
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303248
05/12/17 09:48 AM
05/12/17 09:48 AM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
I suspect that you may have a contamination problem "somewhere". Oil filter, oil pump, oil pick up and fouled pushrods are all possibilities at this point. Does your "ticking" come and go and correspond to your oil pressure drops directly? To me it sounds like something is working under pressure and intermittently failing. If the ticking doesn't correspond to drops in oil pressure, I'd check for good electrical contact at your oil pressure sender just to eliminate that as a possible source of future annoyance. Changing the oil and filter might be a good place to start. have a good close look at the used oil to see if there might be something odd about it,
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303254
05/12/17 10:02 AM
05/12/17 10:02 AM
My sender is mechanical, no electrical connections. Yes the ticking came on with the drop in oil pressure, and went away as soon as the pressure came back. I figured originally that something was getting clogged, and to drop pressure in the whole system my first thought was the pickup tube. Thought the bypass in the filter wouldnt allow clogging. Then I realized Ive never actually seen an oil pump fail, so I posted here for more info
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303256
05/12/17 10:09 AM
05/12/17 10:09 AM
Ottawa, Ontario
Ottawa, Ontario
I'd start with these suggestions first. If you see evidence of contamination, I'd consider flushing out the system with a product and then fresh oil and quality filter to begin. If you don`t know the quality and grade of the oil that was put in there before you bought the truck, I`s suspect it starting now.
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303259
05/12/17 10:26 AM
05/12/17 10:26 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I bought a 1984 truck with a 75000 mile 360 on it from a local dealer. I talked to the previous owner who was a Penzoil faithful and told me how he changed the oil every 3000 miles. The dealer changed the oil before I bought the truck. It lasted about 1000 miles before the detergent motor oil they put in dissolved all the Penzoil buildup and stopped up the pickup tube. I was 100 miles away buying the Cummins diesel to go in the truck when my oil pressure started dropping and my lifters started clicking. I barely made it home. It maintained around 10 psi if I kept it below 50. It shuttered and seized up when I pulled into the driveway at home. I still have the motor. It looks like someone filled the valve cover with black cornflakes!!! Check the filter first and then check the pickup. My first wife's mini van did the same thing when I put in some Lucas oil treatment. It dissolved the Gastrol buildup in little flakes that clogged the pickup tube. It lost down to 10 psi and the lifters really made a racket. I dropped the pan and cleaned out the pickup. I dropped a bearing and it was fine so I cleaned her up and all was well.
Re: Clogged pick-up or oil pump failing? [Re: fastmark] #2303286
05/12/17 11:55 AM
05/12/17 11:55 AM
blewbyu Offline
blewbyu  Offline
I bet the valve seals got hard and cracked into pieces and fell down into oil pan and clogged the pick up screen. How do I know this? violin
This will relate to no oil pressure. I seen it several times over the years.
Re: Clogged pick-up or oil pump failing? [Re: Adam71Charger] #2303290
05/12/17 12:07 PM
05/12/17 12:07 PM
South Florida
indcontrols Offline
indcontrols  Offline
South Florida
Not long ago I worked on a customer's car with the same symptoms... Turned out to be the fuel tank - Yup...
Rusty ass fuel tank kept sticking the Holley needle valve open, flowing a river of fuel, made it "challenging" to start.. Also destroyed the blue rubber 1-piece pan gasket and about a handful of blue rubber was collecting on the pick up screen. Wish I had a picture, it was an unbelievable amount of rubber - especially since the pan was still not leaking !
Page 1 of 3 1 2 3
