Re: 340 to 360 swap
[Re: rscottick]
#2303065
05/11/17 10:14 PM
05/11/17 10:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you knock the weights off make sure you only knock off the imbalance weights only.
Re: 340 to 360 swap
[Re: T2R9]
#2303068
05/11/17 10:17 PM
05/11/17 10:17 PM
RapidRobert
OT there might be a slight difference in the fore/aft spacing of the DR block ears & possibly a difference in the space between the block ears on that same side so check that out & some spacers/washers will take care of that as needed. there are (2) "center sump" 360 pans that I am aware of, the sump(s) ain't exactly center (are more toward the front) but are referred to CS pans as opposed to front "van" or rear "truck" sump pans. On the "392" the sump starts ~4" from a line vertical plumb down from the very front pan lip and on the "876" pan the sump starts ~2". both sumps are ~8" long & they take different oil pickups. visual on your 340 sump/compare it to what you have on the 360 to see if you will be in the clear. Having the eng "almost" dropped all in is definitely not the time to have an issue there!. As said keep the 360 dampener as is up front & do what you need to do to keep the rear part of the external 360 balance on the 360 as it needs to be.
Re: 340 to 360 swap
[Re: rscottick]
#2303073
05/11/17 10:20 PM
05/11/17 10:20 PM
Supercuda
About to go away
About to go away
up yours
340's and 360's use the same motor mount ears, 273's and 318's use another.
But 340 oil pans will not fit a 360.
Re: 340 to 360 swap
[Re: rscottick]
#2303181
05/12/17 01:24 AM
05/12/17 01:24 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
All small blocks use the same passenger side motor mount...the 340/360 use a different driver side mount then the 273/318....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: 340 to 360 swap
[Re: rscottick]
#2303489
05/12/17 07:08 PM
05/12/17 07:08 PM
Posts: 4,407 Michigan
MarkZ
Worthy
Worthy
I have a spare B&M flexplate for an external balanced 360 /w 727 if you need it. I'm also in Michigan.
